Page 21 of 36 FirstFirst ... 1117181920212223242531 ... LastLast
Results 401 to 420 of 717
    #401
    Quote Originally Posted by paolo37 View Post
    ahh kala ko porma lang yung yellow na fogs hehe... balak ko kasi mag palit ng headlight bul ng PXV.. pero yung fogs ko stock halogen color lang... kung gawin kong yellow color yung fogs ko ok kaya sya combination ng PXV?
    In my experience sir may improvement sa pag gamit ko ng yellow bulbs compared to stock, mas intense and mas kita ko ng kaunti ang output from the driver's view. Although very very minimal lang kasi ang purpose lang po talaga ng fogs is to give immediate foreground lighting, still, I noticed the difference. I used Euroline H11 pure yellow bulbs btw but it got busted just last week because of loose connection, nasunog yung socket. But yung bulb hindi sunog, socket lang talaga.
    #402
    Ung friend ko na naka spark nag palit ng Osram night breaker plus.
    Before sha mag palit, straight at malinis ung cut off ng headlights niya. After niya mag palit parang sabog at ma glare ung headlights niya. Dinouble check ko ung pag mount niya nung bulbs, tama naman ung pagka install.
    Ganto din ba nangyare sainyo mga bro? Thanks.
    May 2012
    #403
    dati gusto ko ng osramnight breaker, kaso baka madismaya lang ako, kaya baka mag bosch all weather nalang ako para sigurado maliwanag,
    Apr 2012
    #404
    Buti hindi ako nagpakabit... Hahaha
  5. #405
    Mga 95% sure ako fake yung bulb na nakuha nya. That happens when the filament are not optically centered.
    Here is a comparo I did on the XV and NB+:
    Got to finally do this as I started to import directly Osram NB's and Philips XV and I am starting to offer a unique plug and play HID bulb only for H4 headlights.
    Comparing the outputs:
    headlights are Jazz GD, 1st Gen
    same CAM settings on all
    Stock Osram bulbs (from casa) vs. Osram Night Breaker Plus
    stock vs. Philips Xtreme Vision (XV)
    I measured light output in LUX with a light meter:
    stock halogen bulb = 80-100 lux
    Osram NB = 150-170 lux
    Philips XV = 150-170 lux
    There is a considerable difference between the stock halogen bulb and the NB or XV.
    Between NB and XV
    In actual and same with the pic, it is very hard to see the difference.
    I lowered the headlights to see the actual width of the bulb output. This is showing one headlight:
    Even here, it is very hard to see a width difference although I can see a slight advantage of the XV. I work with headlight output everyday so I can see some small differences but for an everyday, normal driver, this will be very hard to see.
    These are all ORIGINAL AND GENUINE Osram NightBreaker Plus and Philips XV H4's from Germany. Some people say mas matibay yung Philips XV but we need see this first sa long term use. I will also try to do some testings sa H7 or H11 bulbs. All bulbs are now available. Sobrang daming fake na ganito, I went around to check. I am offering the bulbs with FREE installation and alignment of headlights.
    I cannot point enough na ang daming FAKE na Osram NB+ and Philips XV so ingat sa pagbili.
    May 2012
    #406
    may binabagayan din yata ang osram NB. depende sa headlight? kaya siguro blur output ng ibang nakabili or fake na tlga mura na din kasi 1k lang.. dito sa amin P1800 ang Osram NB sa isang kilalang shop.
    question, naka Philips XV na ko, kaso hirap pa rin ako sa wet asphalt sa gabi, will changing my headlight to yellow help?
    Feb 2006
    #408
    Quote Originally Posted by garyq View Post
    Between NB and XV
    Sir garyq ,
    Maybe it's okay for the Mod's if you can post the price for both PXV and NB+ ?
    Hmmm just asking po muna if how much for H7 ?
    Thanx
    Jan 2013
    #409
    Guyz pwede kaya itong Philips Extreme Vision for my Mazda 2 headlight (H4) and fog light (H11) without the need to upgrade wirings, meron kya? would Appreciate ur recommendations since I am planning sna to change for HID and I really have little knowledge abt this. Nahihirapan kc ako kpag gabi magdrive lalo if naulan at nsa highway.
    #410
    Quote Originally Posted by Teenz View Post
    No need to upgrade your wirings as they use the same wattage as the stock halogen bulbs.
    Jan 2013
    #411
    Thanks Chikselog! Are u familiar with the brand DK for HID? Is this brand ok? Planning to buy 4300k for both headlight and fogs. What do u think?
    #412
    I thought you were already inclined on getting the PXV or ONB+ after you created your own thread (http://tsikot.com/forums/car-lights-...zda-2-a-91782/) regarding your plan to upgrade your lighting. Honestly, don't go for plug and play HID. If you want to do it the right way, get your headlights and foglights retrofitted to a projector type.
    We pretty much summarized (on your thread and this thread "http://tsikot.com/forums/car-lights-...-newbie-88128/") every disadvantage of Plug-and-Play (PnP) HIDs on your STOCK and NON-MODIFIED reflector headlamps and you very well know that slapping on PnP HIDs causes glare to motorists in front of you. That's a safety issue and that's exactly the reason why most forumers here are against it. Kapag nabulag ang kasalubong mo maaaring maaksidente yan, or maka-aksidente ng iba like mga pedestrians na tumatawid na hindi nya nakita dahil bulag sya sa ilaw mo.
    So my advice, again, just use the PXV or ONB+, sir garyq already posted the output and trust me, they're much better in person. I drove my friend's Pajero FM when he upgraded from stock halogens to PXV, very nice output. Approximately 80% improvement in overall lighting (width, intensity of light). At magkano lang yan compared to those HID kits, malamang 2 pairs pa nga ng PXV/ONB+ ang mabili mo for the price of one pair of HID kit. And by the way I'm no expert on lighting, one does not need to be an expert in lighting to realize the consequences of using PnP HIDs on non modified reflector HLs, just use common sense.
    Jan 2013
    #413
    Hi there, newbie here..check ko lng is the osram NB plus supposed to be white in color? kc medyo yellowish yung nabili ko, and do i need to re align it? i'm guilty kc of having PNP HIDs on my stock mazda 2 reflectors. hehe pero heard reviews on osram NB plus, ayon pinalitan ko na. Retrofitting is an option sana pero wow ang mahal. Orig Greddy muffler na yun kung sakali.
    #414
    Yup hehe I drive his FM a lot for me to notice the difference from his stock halogen. Medyo nasisilaw lang ako ng konti nung cutoff nung left HL nya ewan ko kung mataas ng onti ang tutok or what. Pero yung color, slightly whitish than stock pero mas intense.
    chiks, i replaced my stock halogens to ONBP, laki ng difference talaga compared to stock. minsan hindi na ako gumagamit ng front fog lights.
  15. #415
    pag orig na halogen bulbs, yellowish yan.
    #416
    Kamusta mga sirs! I'm back!
    Check out my sulit.com Osram Night Breaker Plus Ads for more info.
    OSRAM NIGHT BREAKER PLUS H1 H3 H4 H7 H11 HB3 HB4 Halogen Bulbs Philippines - 6165515
    Also check my 100% feedback on how buyers are satisfied with the Night Breaker Plus!
    All bulbs that I'm selling are original/genuine. I can provide sales invoice from my German supplier if you wish.
    Coming soon... Osram Night Breaker Plus Limited Edition!!!
    20% whiter than stock bulbs and gold plated tips!
    These bulbs are ORIGINAL/GENUINE!
    I can provide sales invoice from my German supplier, if YOU wish...
    H4
    H7
    Sep 2005
    #417
    magkano naman sir yang H4 Osram Night Breaker Plus Limited Edition?
    #418
    Ranging from php1,700 to php2,000. Still haggling sa price with my supplier.
    #419
    Stocks just arrived...Get yours now!!!
    H1-Php1,150
    H3-Php1,150
    H4-Php1,200
    H7-Php1,250
    H11-Php1,650
    HB3-Php1,550
    HB4-Php1,550
    ¤¤¤ Meet up points ¤¤¤
    Php50 (Handling fee)
    Makati - Along Pasong Tamo and Ayala Ave.
    Alabang - Festival Mall & Alabang Town Center
    Las Piñas - SM Southmall
    Parañaque - SM Bicutan & Shopwise Sucat
    Taguig - Market Market
    MRT - All MRT Stations (North Ave. to Taft Ave.)
    Laguna - Sta. Cruz and Pagsanjan
    ¤¤¤ Nationwide delivery ¤¤¤
    with insurance - Php170 (buyers expense)
    ¤¤¤ Payment Method ¤¤¤
    BANK DEPOSIT
    G-CASH
    THRU MEET UPS
    LBC
    CEBUANA LHUILLIER
    WESTERN UNION
    ¤¤¤ Contact Details ¤¤¤
    Number: 0917-757 8484 / 0922-858 8484
    ***All bulbs that I sell are ORIGINAL/GENUINE.
    #420
    Ano naman kaya magiging difference if I replace my stock foglight bulbs with this h11 osram NB+?
    Sent from my iPad using Forum Runner
Philips X-Treme Vision Vs. Osram Night Breaker Plus
