Results 191 to 200 of 246
August 3rd, 2018 12:34 PM #191
August 3rd, 2018 01:00 PM #192
I have 2 cars with 3M CS20 windshield and CS05 sides. Then another one with Vkool OEM20 all around.
I prefer having 5% VLT on the sides and 20% VLT for the windshield. Better aesthetics and more privacy, without severely compromising drivability at night. Just last night I was able to drive down Baguio under zero visibility fog with my 3M CS20/CS05 combo:
Do note that even if I have OEM LEDs and HIDs on the cars, lighter tight even with just halogen headlamps still has better nighttime visibility.
August 4th, 2018 06:36 AM #193
August 4th, 2018 11:20 AM #195
30 for the WS is just perfect for me. With 20 or less sa sides, you won't be visible outside anyway. Then 70 sa sunroof to maximize light once you open the shade.
Unsolicited advice: if you have the budget go ceramic [emoji106] CERAMIC TINT vs REGULAR TINT (yuuuge difference) - YouTube
- Oct 2018
- 1
October 7th, 2018 08:50 PM #196Some window film (ceramic based) perform as well as other sputtered/reflective films during live demo. However to further test the performance, expose it to higher heat and longer duration of time - and compare again. Ceramic based films absorb heat energy and over time, heat still seeps through. While sputtered films reflect heat away, resulting in consistently high performance even after long periods of time.
Difference between IR Rejection and TSER | Window Tinting | Window Film Singapore | Pacco Chemical
October 20th, 2018 05:29 AM #197
Hi Guys, aesthetically from the outside, which.one is better in a silver car? Vkool K series or the OEM's?
Kung OEM im planning 05 wrap around except WS which will be 20.
Sa K naman K14 wrap around except WS which will be K28.
My order of concern is outside aesthetics then visibility last heat rejection but i guess from the choices heat rejection would be more than sufficient already.
TIA.
Sent from my ASUS_Z017D using Tapatalk
- Jun 2005
- 3,774
October 21st, 2018 01:25 PM #198
October 21st, 2018 03:22 PM #199
October 23rd, 2018 03:50 AM #200
Ok din kinalabasan OEM 20 WS then 0EM 5 the rest.
Yeah, they tried with the styling but one can still see that it is not very Mazda like when...
2022 Mazda BT-50 (3rd Gen)
