Results 31 to 34 of 34
June 14th, 2006 09:35 PM #31
Originally Posted by wildthing
Yup, the original battery lasted for 1 1/2 yr. try ko lang ito. i use original car and home charger naman.
June 15th, 2006 03:17 AM #32
if you're looking for rechargeable batts and chargers i suggest that you get the powerbase brand. they usually sell it as a a set charger and batts. magand ayung charger nila
regarding hte jakolites ok naman cya in case of an emargency and provided pitch black yung surroundings. malakas cya pag ganun
June 15th, 2006 09:35 AM #33
Originally Posted by resmile
eto ata yung for a 5 minute light, you need to shake it for 30 minutes....
June 15th, 2006 10:22 AM #34
One time, I bought a 180 pesos worth of sony-ericsson car charger(12volts)from a muslim trader at atc -- sa tapat ng National Bookstore...mga 6 months din nagamit. Nung nasira, I checked why? Umurong pala yung charging pins and contact was no longer existent between terminals of the charger and the phone. I pushed the pins to reach the terminal and put loctite. Ok na but after some 3 or 4 months, same sira. This means that the material of the cheap charger is sub-standard because my orig charger for home ac outlets(120 volts) has been with me for two plus years and still running ok.
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
