Results 1 to 10 of 21
- Oct 2005
- 72
December 11th, 2008 04:40 PM #1Dear Tsikoteers;
Please give me advise about experiencing "shift shock" when you shift from P to D or R. May problema ba ang tranny if may naramdaman ako na shift shock di naman gannon ka lakas pero may ramdam mo.
but during draving wala problema naman sa hatakan ok siya?
Apprecaited your advise in advance
December 11th, 2008 05:26 PM #2
Try having the auto-tranny fluid drained and replaced. Also have the filter replaced as well. If the shift shock is still there, it might require more expensive repairs to fix.
December 11th, 2008 05:48 PM #3
........Can you please elaborate this "shift shock". If it means it jerks when you shift to D, your engine's RPM might be too high because the engine has not attain its normal operating temperature and the ECU is feeding more gas to the engine. But if the RPM is still high even at normal operating temp of the engine, you may want to adust the air fuel mixture to have the correct RPM, IMO.
December 11th, 2008 06:09 PM #4
or baka naman me naririnig sya tog sound pag nag kakambyo sya from park to DRIVE
December 11th, 2008 06:25 PM #6
Shift shock is the jerky transition when the automatic tranny shifts between gears.
December 11th, 2008 06:43 PM #7
Ah ok,
http://tsikot.yehey.com/forums/showthread.php?t=31796
Shift to the "D" position, and try to drive gently, with smooth and gradual acceleration. Until the vehicle reaches a speed of 50-60 km/h or 30-37 mph, you should feel the gears shift at least twice (from first to second, and from second to third). These shifts should be made very smoothly, without jerks or slipping.
By "smooth shift" I mean it should be smooth but you should feel it at the moment the rpm drops down; it feels like the car slows down for a very short instance and then accelerates again. You also can note the transmission shifting moment by the slight change in the engine tone.
But when the transmission is extremely worn it may shift with quite a strong jerk, shudder or a delay (especially from first to second speed).
Driving at a speed of 40-50 km/h or 25-30 mph, if you press down the accelerator pedal for a few seconds, you should feel downshifting to the lower gear, if the automatic transmission works properly.
Taken from the Link, hope this will help.
December 11th, 2008 06:45 PM #8
ako din sir naexperience ko jerk sa shifting A/T due to high rpm, so ang ginawa linis ng MAF, choke, air filter at palit ng intake sensor.. ayos na naman...
pero pag malakas nga yung jerk as in me "thud" sound pag reverse, drive or neutral.. sure me tama na yung gear mo...
December 12th, 2008 12:30 AM #9
- Nov 2005
- 30
December 13th, 2008 08:37 AM #10
Megaforce lasted 4.5 years ... with CTek charger ...
