Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Jul 2006
    Hi Guys,
    I'm new with A/T cars... I'm driving a Toyota Corolla Altis 1.8 S.E.G. everyday to work... however, I'm having a delay response every morning when shifting to D (about 3 or 4 seconds) before my car runs... but after that, it works fine all day... can anyone help me on this??? pls...
    I'm also looking to modify my transmission to make it faster (I want to make it run as fast as possible)... what are modifications that I need to do???
    Thanks a lot!!!
    May 2011
    Quote Originally Posted by neozeke View Post
    Hi Guys,
    Thanks a lot!!!
    before you run off every morning, warm up your engine first. check your transmission fluid regularly.
    i don't think you can modify a/t transmissions to make it run / respond faster. mabagal talaga response ng a/t, hindi mo pwede pilitin/ stress ang a/t to respond like a m/t.
    kailangan maingat ka sa shifting kung hindi sira na agad transmission mo and minsan pati engine support.
    Jul 2006
    Quote Originally Posted by mramora View Post
    paano pong maingat sa shifting??? I usually just shift to D and then N pag traffic or stoplight... regarding engine support, what will be the effect pag nasira ung engine support?
    thanks a lot.
    May 2011
    thanks a lot.
    like pag shift ka from D to R, hwag diretso pasok sa R, daan muna sa N kasi mastress yun tranny. ok lang yun D to N
    a brandnew transmission would cost you around 400k
    if nasira engine support mo, may kalampag/vibration/noise sa unahan everytime you accelerate and break or any sudden change in direction. made of plastic lang kasi yun engine support. the weight goes to your tires, parang pakiramdam mo napuputol na yun axle. your tire threads will wear off faster and the list goes on and on sa lahat ng matatamaan.
    Jul 2006
    oh i see... wala pa naman kalampag... may naririnig lang ako sir na konting noise (tunog ng pasara ng pinto pag horror movies) pag nagbrebreak... pero tahimik naman sa pag accelerate and turn...
    napansin ko din kaninang umaga, parang ang tagal nya mag shift ng gears... have you guys experienced this??? thanks!!!
    Jan 2009
    Sometimes, using the wrong ATF does that. At worst, using the wrong ATF type will reduce the life of the A/T components.
    Jul 2006
    may suggestion ba kayo kung anong best ATF na gamitin??? I'm thinking of a car tune up one of these days tapos Royal Purple oil sa engine pero di ko pa alam kung anong ATF eh.... thanks!!!
    May 2011
    siguro yun noise na naririnig mo sa panels. plastic ba interior panels? same din with our GE maingay yun mga plastic panels pag dumaan ka sa matagtag or sa humps.
    you mean matagal response ng gear? sa ATF yun. usually sa casa kami lagi nagpapaservice kaya sila na yun bahala sa ATF na ginagamit. btw boss babae po ako.
    Jul 2006
    ay, sorry po mam... wahahaha... my bad...
    sana nga sa ATF lang... nung huling nagpa service kasi ako, pumunta lang ung mekaniko ng servitek sa amin... dun pinalitan ung ATF ko... dad ko lang bumili ng ATF from Caltex Gas Station so hindi ko alam kung ano ung nilagay... hehehe... I'll try na ipaservice ung car ko sa weekend...
    another thing, bakit umiinit ung sa ilalim ng shifting knob? dun sa area ng tranny... ganun ba talaga un??? thanks!!!
    Jul 2010
    di kaya lotion nabili ni Dad? nyahaha joke lang bro...
    sa ATF yan most probably....
A/T delay response in Drive every morning
