Page 17 of 17 FirstFirst ... 71314151617
Results 161 to 169 of 169
    Mar 2018
    #161
    Quote Originally Posted by reymund View Post
    Another, does switching OD off consumes more fuel?
    Sent from my SM-A710F using Tapatalk
    Presumably since the RPM will be higher compared when OD is on.
    Sep 2018
    #162
    Agree [emoji4] thanks.
    Feb 2015
    #163
    How to reach 6K rpm in a 4AT? The manual says that #2 shift should not exceed 80kph.
    Car is NA at 155hp * 6K rpm.
    #164
    Quote Originally Posted by kebloks View Post
    I reach 6k rpm all the time with my 4AT car. Just use the manual override function - either put it in 2 or use the manual mode and select second gear.
    What car is this?
    Feb 2015
    #165
    What car is this?
    Ford Escape 2.3L. Is it safe to put it in 2 and exceed 80kph?
    I tried to floor the accelerator while in D but it just briefly reached 5K rpm for 1 second and upshifted.
    #166
    As long as your car is in good shape, it's perfectly fine to rev your engine to its redline every now and then.
    #167
    Italian tune-up.
    Oct 2018
    #168
    Quote Originally Posted by jaeger View Post
    on your concern to be able to drive it correctly . . . .
    most auto-trannys have pre-set shift points. Some have economy and power buttons (like mitsu's). Know your cars AT shifting points so you don't unneccessarily over-rev your engine. Also check the rpm when your torque converter locks up - this is when you have a speed gain of say from 60 kph to 80 kph but your rpm remains pegged at 2,000rpm - that's your torque converter locking up (wala nang slippage) delivering additional speed without engine having to rev up higher (this was on my old D16Y8 AT).
    Drive it right, an AT doesn't necessarily mean higher fuel consumption.
    I have this old cinverted Mitsubishi Delica from Japan I think theres a problem with the solenoid if there some good talyer in Pasig or Taguig or Mechanic who is good at repairing delicas auto transmission and over drive ha ha ha ha I mean good mechanic meron ksi good maningil joke lng maybe youd be kind enough to advice me if you know one thanks
    May 2019
    #169
Question re Automatic Transmission Driving Technique
