Results 11 to 18 of 18
September 2nd, 2005 07:18 PM #11
un ba ung parang loud bass-y sound na parang humihigop ng hangin pag ni-rev mo ung engine?
sinabi mo pa, kaya parang laging labor ung makina ng delica ko lalo na pag above 100kph...
di lang ako makapiyok sa tatay ko....masyadong nagmamagaling din kasi,e...
September 3rd, 2005 01:29 PM #12
Originally Posted by ravelcop
September 4th, 2005 07:06 PM #13
Around two to three. But this is on a 4D56 diesel engine. Be sure to replace the big O-ring so you won't have leaks. And use impact screws driver para madaling nag alis and tight ang mga screws. Sa Denso sa Banawe mayrun.
September 5th, 2005 12:26 PM #14
thanks afrasay!
how would we know na tamang-tama na yung silicone oil na nilagay ko without mounting the fan back? pwede kayang pakiramdaman lang by turning the fan by hand? nakakapagod kase pag tanggal-kabit eh
is it true na pag cooler temperature, pwede mo pigilan ang fan with your hand when starting the engine? i was thinking kase na its logical coz silicone oil must be softer by then.
September 5th, 2005 07:23 PM #15
Sir Afrasay, sa Revo na 7K-E ang makina, ano kaya ang nakalagay na fan clutch, is it sealed type be o hindi? And twing kailan mo dapat palitan ito in terms of kms na naitakbo nito? Yung sa kin kasi maingay din pag-andar nya and nasa 90kms na itinakbo nya. Do you think kailangan ng lagyan ng silicon oil ito?
September 5th, 2005 10:31 PM #16
Hindi noise supressor ang silicone oil. If the fan still 'freewheels' even when the engine is hot, that is the time to add oil.
Even seemingly 'sealed' fans can still be opened up for refills. Afrasay's mechanic cousin Ferdie can probably do it for you if the mechanics in your area wants to take the lazy way out and just weld the fan solid to the shaft.
September 6th, 2005 08:45 PM #17
just fill up one side pag na biyak mo na yun mechanisim. yes, you can hold the fan while someone starts the engine. the silicone hasn't expanded/harden yet when the engine is cold. i don't know if the fan in a 7k engine is serviceable. you'll know it if you see screws around it.
September 9th, 2005 01:35 PM #18
depende s size ng clutch fan 1-2 vials oks na ngeexpand kc yn. kung rekta m nmam syang babagal ka extra load yn s engine bababa horsepower At torque ng engine at high speed
Could also be due to the high demand that the manufacturer prioritized new car deliveries vs. spare...
BYD Sealion 6 DM-i
