Results 1 to 9 of 9
- Dec 2002
- 16
October 2nd, 2003 04:20 PM #1Yung car is AE101 gli 93 . Napansin ko na mga 1 month na, ang clutch ko ay mahirap maglipat ng gear kung minsan. parang may hangin sa line ng hayraulic. nagpalit ako yesterday, pero lumala. nai-bleed naman siya tapos pinalitan ko ng bagong brake fluid. pero ganun pa rin. ano kaya ang problema nito. pls help. thanks
October 2nd, 2003 05:20 PM #2
check your synchro. baka worn out na. and check the gear oil level/condition
October 2nd, 2003 10:23 PM #3
pag may sipa na yan stick mo baka nga synchronizer na yan.
baba ng gear box, complete inspection. malamang bili ka ng synchronizer keys and synchronizer gears. kung may budget ka palitan mo na rin mga bearings para minsanan ang gastos.
and since nakababa na gear box mo, check mo na rin clutch pressure plate, disk saka release bearing.
October 2nd, 2003 10:25 PM #4
or shifter bushing lang ang problem, pwede din. yun ang plastic bushing sa end ng stick. alisin mo yun cover ng stick, remove mo yun 4 small screws holding the stick to the floor then hugot lang. check mo baka naman worn out na yung bushing.
- Dec 2002
- 16
October 4th, 2003 01:21 PM #6rod, you mean yung cables from shifter to transmission? nope , lagi ko nilalagyan ng lubricant yun.
What i mean is that sometimes, lumalambot masyado yung clutch pag inapakan ko. kaya ako nagpalit ng repair kit ng master hydraulic clutch. nai-bleed naman ng maayos bako ko inuwi pero parang lumala. may kinalaman ba dito yung brake fluid na ginamit ko?
BANNED BANNED BANNED
- 3,790
October 4th, 2003 06:33 PM #7That's weird...imo its not a hydraulic fault...may be the gear box set-up.
Hydraulic will usually show some symptoms like leak and fluid reduction in the reservoir...
my 2 cents.
- May 2019
- 6
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
