Results 1 to 10 of 18
May 16th, 2005 04:23 PM #1
mga bossing, have you encountered hearing a grinding sound while shifting to reverse? i thought na normal lang yun but as i could hear it, parang hindi nagmemesh ang gears niya kaya meron grinding sound when i shift to reverse. although dun lang sya umiingay, pagkapasok na, ok naman ang takbo. What i was wondering is, hindi sya nangyayari always, most of the time lang. merong times naman na hindi ko maipasok to reverse. so what i would do is binibitawan ko muna ang clutch, then step on it again, then kambyo ko ulit to reverse. then i would hear that grinding sound for a second tapos pasok na sa reverse. weird no? natatakot na ko coz tunog talaga ng gears ang grinding sound.
May 16th, 2005 04:29 PM #2
Im not sure bout that pero subukan mong apakan ng husto yung clutch mo kung ayaw pa rin pagawa mo na sa mechanic mo.
May 17th, 2005 12:01 AM #3
Originally Posted by paulopel
hay hay hay.
pareng ravelcop, check the clutch master..baka sira na..may repair kits naman yan eh.
May 17th, 2005 12:06 AM #4
sa akin nangyayari ang ganyang sound when i dont apply the clutch thoroughly. you can try that for starters then work from there..
May 17th, 2005 11:23 AM #5
yes, it happens pag half press ang clutch. kaya suggestion din ng mechanic isagad. pero kung same pa din kahit sagad na. take sir glennster's advise...
May 17th, 2005 01:48 PM #6
ano ba car mo bro?
sakit daw yan nang mga honda pag more than 5 yrs na car mo.
synchro malamang ang sira nyan kung reverse lang sya or kasama primera.
Hope this help. Kahit half press ang clutch hindi sya grind nang ganun kalakas hirap nga lang sya pumasok.
kaya sya grind may sira ang bushing sa tranny, synchro or clutch master ang sira. Kung sychro magdasal kana kasi sobra mahal nun malamang pagtyagaan mo na lang yan at hintayin na total masira para bumili ka na lang nang bago na tranny.
Si speedyfix ganun din sira dati nang car nya sya nagsabi nun kasi ganun din sira car ko.
my two cents.
May 17th, 2005 02:01 PM #7
Nissan Vanette '95 bro
sa reverse lang sya nakakaganun, grinding sound na malakas na parang hindi nagmemesh ang mga gears. yung tipong hindi kumakagat ang gear sa kadena, alam nyo yun? pero tumutunog lang sya whenever galing akong forward. at minsan naman eh hindi sya tumutunog. Talagang hindi mo malalaman kung kelan sya magkakaganun, very inconsistent kung baga. Sinubukan ko na ring sagarin ang pagtapak ng clutch pero ala-epek
May 17th, 2005 02:22 PM #8
Originally Posted by CLAVEL3699
May 17th, 2005 02:31 PM #9
Originally Posted by ravelcop
Hope this help tingin ko nasa forward motion ka tapos reverse mo.
May 17th, 2005 02:32 PM #10
Originally Posted by WeaponX
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
