Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Dec 2004
    Quote Originally Posted by umzzzzz
    pano procedure nito sir?
    sir, usually, ang basic procedure is may luluwagan kang bleed screw (not sure with civics) then bobombahin yung clutch pedal para mailabas yung hangin. once back to "normal" level na yung pedal (minimal play), natanggal na yung hangin.
    you would need a helper (or a friend) na magbobomba nung pedal, and a small bottle of clutch fluid, as you would need to top off the reservoir in the process, and may tatapon ka ring fluid. mapapansin mo na may air bubbles na lalabas sa may bleed screw habang binobomba yung clutch. once ok na, higpitan lang yung bleed screw and fill the reservoir properly.
    one note - some vehicles need to have the ignition turned to "on" para makapag-bleed.
    HTH.
    ganito pala...
    magulo lang yung illustration ... napagpalit nila ang label ng "SWITCH A" at "SWITCH B"
    if a mechanic strictly follows the text and the illustration, he will never finish the job
    Aug 2015
    Quote Originally Posted by umzzzzz View Post
    ganito pala...
    mga sir patulong po. base po sa pic ok naman ung letter A at B ng clutch pedal ko. pero ung C po 4 inches lang tapos ung D 0.5 inch lang. ok lang po na ganun?. pinabago ko kasi ung taas ng clutch pedal ko dati, dati halos 1 inch ang taas sa brake pedal, pinababaan ko ng half inch na mas mababa sa preno..
    medyo hindi smooth ung shift ng gear kumpara sa dati. nakaapekto po kaya un?
    civic 2000 mt. bago palit clutch master at slave. clutch assembly?( un pong disc, plate at bearing) mga 20k kms pa lang. gear oil parang last year lang ako nagpalit. thanks.
    Aug 2015
    tsaka anu po ba ibig sabihin ng clutch slippage?
    Jun 2011
    POssible kaya may free travel
    1. Yung bushing sa kinakabitan ng lock nut C
    Baka wornout na
    2. Yung mismong arm na nakakabit Yung lock nut c may free play na.. It needs to be rebuilt na.
    3. May free play na Yung bolt ng arm-- needs to be rebuild na din..
Clutch Pedal Free Travel
