Results 1 to 4 of 4
November 7th, 2011 01:06 AM #1
isuzu ls 1994 model pickup ko.. kakapaayos ko lang nung clutch pinalitan yung buong clutch assembly last june ata yun.. tapos after last month (october) bumalik na naman sa dati lumubog ulit ung clutch.. hindi naman literal na lubog kelangan mo lang tapakan ng sobrang lalim para lang pumasok minsan nag ggrind na ung gears.. kaya pina adjust ko yung clutch tapos okay na ulit.. this time onti onti na naman bumabalik yung sira ano kaya problema nung clutch ko?
November 10th, 2011 09:59 PM #2
baka may leak, kaya lumubog, pa check mo uli yung rubber sa master baka may tama or mismong yung cylinder ang may defects..kung ok naman lahat, check mo sa mga pipings..
November 10th, 2011 11:50 PM #3
November 11th, 2011 03:40 AM #4
iadjust mo ulit sir yung push rod, kung saan ok na ipasok yung gear, sa pedal lang naman yan or dun sa secondary kung meron
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
