Results 41 to 50 of 370
- Aug 2009
- 420
January 5th, 2013 10:36 PM #41
January 6th, 2013 09:20 AM #42
Royal purple sir pag synthetic kung kaya budget.... Yes i used a dialysis machine para change ng atf... As for the total amount ng atf for trooper and pajero, para sa exact liters you can ask the casa ng mitsubishi and isuzu para malaman yung amount ng atf then pag alam mo na saka bili sa labas atf...
For our two vehicles, on the average it's around 10 liters to 12 liters pag complete dialysis..
- - - Updated - - -
- Aug 2009
- 420
January 6th, 2013 02:10 PM #43
wow 10 to 12 liters worth 800 per liter, wow... i thought u needed 17 liters for atf change using dialyis, ung alam ko mga 8 to 9 liters lang gagamitin sa atf.
- - - Updated - - -
January 10th, 2013 09:40 PM #44
sa mga suv na vehicle namin usually 10-12 liters per vehicle.... medyo mahal pag RP, pero i think sulit naman... there are also other good brands out there na mas cheaper if on budget... depende na lang yan kung dexron III ang need na atf, kasi mura ang dexron III compared to other atf specs...
- - - Updated - - -
- Aug 2009
- 420
January 11th, 2013 09:27 PM #45
- Feb 2006
- 771
January 11th, 2013 09:50 PM #46Any idea if any ATF changing using Dialysis procedure sa banda South of MM?
Preferably in Alabang , Las Pinas or Cavite Area?
Thanx
- Feb 2013
- 10
February 27th, 2013 10:58 AM #47hello ask ko lang mas maganda ba pag mgpapalit ng ATF eh yung complete dialysis ba,or ako na lang bbili ng oil then sa iba ko na lang ippgwa.alin po ba mas okey?kase ng inquire na po ako sa omni ang dialysis process nila is 8k..masyado lang po ako namamahalan..or baka po my makapg suggest na ma mura here in laguna area...honda city idsi po ang car ko...thanks sa makakasagot
February 27th, 2013 11:21 AM #48
sir pag sayo ang atf fluid at purely dialysis procedure lang ang babayaran mo mura lang yan...
sa fronte sa banawe around 800 pesos lang charge nila....
ganun din ata sa exalta....
search mo sir fronte banawe... basta magdala ka atf mo na gagamitin at least yung total amount ng kotse plus 1 liter na extra just in case...
tapos pag inalok ka ng mga mechanic ng atf additives at kung anu-anu wag ka pumayag, sabhn mo purely dialysis lang at di ka bibili products nila... racket nila yun mga additives at own products nila..
- Feb 2013
- 10
February 27th, 2013 11:46 AM #49
February 27th, 2013 07:21 PM #50
ay pasensya, baka mag kasing edad lang tayo.. hahaha...
mam, personally di ko kabisado kung saan auto shops meh dialysis ng atf sa laguna... pero you can try to ask po mam sa mga malalaking auto repair shops sa city... pero if wala ka makita mam, sulit pa rin dumayo sa banawe sa manila, pm mo ako para help kita sa banawe area...
Di ko alam about sa miata. But I was able to help my uncle acquire a unit para sa pinsan ko kasi...
6th Gen Mazda MX-5 Miata
