Results 41 to 50 of 82
December 19th, 2007 06:09 PM #41
userfriendly and kbr, mga sir thanks for the reply. i appreciate it.
December 20th, 2007 11:17 AM #42
question to longtime honda A/T users: i've read a lot of threads about the negative effects of not using the specified ATF, is this true. will my honda A/T have a shorter life if i will use other ATF brands?
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 20th, 2007 06:05 PM #43IMO, ATF is manufactured to a certain standard and does not differ in composition regardless of brand. Meaning cheap petron ATF will perform the same as a more expensive brand. Provided that both are Dexron III. There is a difference in performance between mineral DEX III ATF and synthetic Dex III ATF. Synthetic supposed to be a lot better.
However, there are different specifications. They are not compatible. So you can not use Dex III if your manual specifies something else like Type F. Using the wrong type ATF can cause tranny problems.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 20th, 2007 10:24 PM #44it's ok to use dex3 on the tranny... drain it well and if possible do consecitive drain/refills to get all the dirty atf out.
April 28th, 2008 02:48 PM #45
Questions po, mga masters! ang ride ko po is a 96 corolla GLi A/T, at 90+T kms odo reading na. My question is, since di ko pa nakuha yung history nito as far as the ATF is concerned, ano basis ko for an ATF change? Based on the oil from the dip stick, somewhere between pinkish and lighter brown na yung color. Wla pa din naman akong nararamdamang shifting problems (delay, harsh, etc). Pero my gut feel is teeling me to change ATF na kahit sabi ng mechanic ko (who happens to be my brother-in-law), eh ok pa daw naman yun.
Also, meron bang shops nn nagi-specialize in AT's na merong free check-up? Yung hnde po nana-naga ng mga di gaanong marunong sa kotse (hehheh).
And for those who have tried changing the ATF of their big body corollas, how many liters did you consume?
Thanks a lot and I really appreciate whatever help you can extend.
- Nov 2003
- 3,848
April 29th, 2008 08:29 AM #46imo, when in doubt palitan mo nalang if you wanna play it safe.
the number of liters you will consume depends if you are doing a simple drain/refill or a transtech sort of procedure.
- May 2004
- 903
April 29th, 2008 01:46 PM #47May Filter ba yung A/T ng Nissan Sentra Series 3? How do I Check for the ATF naka start ba or naka patay yung Engine?
- Jun 2006
- 2,605
April 29th, 2008 05:49 PM #48This is normally the way to check ATF level.
1. Drive your car to warm engine to normal operating temp.
2. Park on level ground, keep engine running through entire procedure.
3. Engage hand brake.
4. Step on brake.
5. Shift to P and hold for 2 to 3 seconds, do the same to the rest of the gears. So P R N D 3 2 1.
6. Open hood, locate ATF dipstick. Note not the same as oil dipstick.
7. Pull ATF dipstick and look at the color. Should be redish, if brown or black it may be time to change.
8. Smell it, should not smell burnt. If it smells burnt, replace it.
9. Wipe dipstick on clean white rag or tissue. Inspect for solid particles.
10. Insert dipstick and hold for few seconds.
11. Pull out and check level. Should be between high and low mark.
- Nov 2003
- 3,848
May 4th, 2008 04:05 PM #49that's a pretty good list. follow it and you should be fine for checking the atf.
- Oct 2007
- 120
July 2nd, 2008 01:55 PM #50
Is it just me or have traffic worsened this week compared to pre-Holy Week? Is it because people...
Traffic!
