Results 11 to 20 of 20
- Apr 2016
- 130
November 12th, 2016 06:18 AM #12
November 12th, 2016 08:15 AM #13
- Aug 2016
- 3
November 12th, 2016 08:39 PM #14Mga paps pasingit nmn po any idea nmn po bout may mitsubishi lancer 95glxi pag bagong start ung makina kahit nka drive n ayaw tumakbo, tas delay shifting n sya pag mag reverse nmn po ako kumakadyot ng malakas, tranny npo kya to? How much po kya mggstos k dto? And san po meron magaling n gumagawa ng tranny novaliches area...thanks mga paps in advance
November 12th, 2016 08:46 PM #15
Pag naka neutral and switch on ang a/c... ano resulta?
- Aug 2016
- 3
November 12th, 2016 09:50 PM #17
The ATF has very little to do with shift points. Shifting is done through solenoids that are directly controlled by the ECM/PCM. What you're noticing might be normal.
When accelerating, if the gas pedal is pressed lightly, the ECM may shift early to be more fuel efficient (unless it detects more load or if the vehicle is going going uphill). However, if you mash the gas pedal to the floor, the ECM knows that you want maximum acceleration and so, it will typically delay shifting to get the most out of the engine's power band.
When you take your foot off the gas pedal, the A/T behaves differently depending on the vehicle. Modern A/Ts will only shift down when the brakes are engaged and/or if it detects that the vehicle is going downhill. It will also shift down when the speed is low enough so it will be at the correct gear and be able to accelerate immediately as soon as you step on the gas. Otherwise, it keeps the current gear to allow the vehicle to coast more freely, again to increase fuel economy.Last edited by oj88; November 12th, 2016 at 10:00 PM.
- Apr 2016
- 130
November 13th, 2016 08:01 AM #18I think this is a good explanation on what im encountering, so do you think its normal that it doesnt shift to 2nd when slowing down to conserve more fuel? Since it will directly shiftto 1st in near stop i guess u really saved my ass by overthinking too much
Sent from my SM-G930F using Tsikot Forums mobile app
November 13th, 2016 08:51 AM #19
A/Ts behave slightly different from vehicle to vehicle. Unfortunately, I've never driven a Mazda to form a more definitive answer. However, the particular behavior you described still seems to fall within the norms of A/T operation. Shift points are never a fixed value. Like other parameters such as air/fuel ratio, it responds to pre-determined maps based on sensor inputs (ie. Engine load, RPM, speed, accelerator pedal position, coolant temp, etc.) and shift points are changed dynamically depending on what the ECM/PCM 'thinks' is the most efficient way to shift up or down.
Also, the reason you have low gears (1/L, 2, D3, etc.), aside from its other obvious uses, is to give the driver the option to engage engine braking if he deems it necessary. Otherwise, if you leave it in D, the A/T logic takes over all control and just rely on its own sensors to decide what to do.
Sent from my iPad using TapatalkLast edited by oj88; November 13th, 2016 at 08:59 AM.
- Apr 2016
- 130
November 13th, 2016 02:13 PM #20Yeah i think mazda has differen way kg matic transmission anw thanks for the help it really clears my mind thank you
Mahilig kasi sa profit ang ford. Strategy yan na huwag gawing matibay ang mga parts para maraming...
BYD Sealion 6 DM-i
