Results 1 to 7 of 7
May 27th, 2007 02:46 PM #1
-a friend of mine is getting an lxi automatic from his brod and wants to convert it to manual. no ba parts na kelangan sa convertion. and any idea on how much it would cost. thanks
May 27th, 2007 03:14 PM #2
Pedal assembly, clutch cylinder, flywheel and manual trans, maybe different prop shaft if rear drive yan, different mounting points if necessary (kung pareho lang it won't matter di ba), shifter lever, boot, and linkages will be different, yung electronics niya from key ignition tumbler will also be different (instead of braking to remove from park, you have to step on clutch to remove from park - I know not all cars have this but you didn't indicate what car)...
Just an idea of what you're to do. Goodluck.
May 28th, 2007 02:33 AM #4
Sell it, buy a manual. The conversion will cost you quite a bit.
- Nov 2006
- 103
May 28th, 2007 10:23 AM #6
yung sakit ng ulo pre sa convertion walang kapalit yun.. like what they said sell it and buy a manual car.
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
