Results 11 to 20 of 61
August 20th, 2013 10:21 PM #11
August 20th, 2013 10:40 PM #12
Given the flat elevation (walang rampa), i think you'd need a lot of speed to clear that gap. You'd also risk a roll over if ever you partially make it across i'd guess. I'd definitely brake the hell hard if that happened in front of me.
Baka Dmax, SiR or MS, kaya italon sa sobrang tulin. :D
August 20th, 2013 10:42 PM #13
August 20th, 2013 10:53 PM #14
Papunta pa naman ako ng subic sa weekend..
So sa pampanga na daan ko ba?
Sent from my Omega HD 2.0 using Tapatalk 2
- 3,754
August 20th, 2013 10:54 PM #15kahit siguro high speed pa kung flat surface hulog ka pa din dyan...pag nag hang na yung 2 front tire mo on the same level um sure gravity will pull you down
August 20th, 2013 10:57 PM #16
August 20th, 2013 11:00 PM #17
August 21st, 2013 01:03 AM #19
Kung from nlex to dau to sctex bound to tarlac di apektado.
pero if via sctex, that is between clark and porac
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
