View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 10,311 to 10,320 of 11542
April 7th, 2016 06:58 PM #10311
April 7th, 2016 09:37 PM #10312
Ito naman sample job quotation for 80k pms
April 8th, 2016 04:01 AM #10313
*kimbon & Devin miles
Salamat
btw pag gusto ko totally drain the coolant, ilan liters need ko to refill? may nagsabi 4, may nagsabi naman 6. salamat
April 8th, 2016 07:09 AM #10314
April 8th, 2016 08:10 AM #10315
April 8th, 2016 09:28 AM #10316
April 8th, 2016 09:57 AM #10317
April 8th, 2016 10:36 AM #10318
April 8th, 2016 08:59 PM #10319
April 8th, 2016 09:45 PM #10320
Thanks to both of you for sharing these infos. Lesson learned...never ever change your coolant when it reached 100k mileage . Case Closed coolant issue kumpanero.
bro 4 liters ang sa vios. may konting matitira mga kalahating baso ng coolant kapag ibinuhos na ang 2nd container (2 lts) sa radiator.
if you don't mind tips for draining & refilling the coolant.
1. flush the radiator with water -when the coolant is totally drained from radiator, flush it with water using garden hose. to make sure only ma-flush out ang kalawang or small debris inside ng radiator.
2. Coolant Refill- fill up until coolant is visible but a few inches below cap level of the radiator. Start the engine but don't accelerate. the coolant level will lower as the engine sucks in coolant. Continue to fill with coolant until the level stabilizes then install and tighten the cap.
3. finally, fill up the plastic coolant reservoir with coolant up to max level only. Hwag punuin ng coolant pls. Goodluck bro.
oo nga naman! aftersales. piyezas. i read of horror stories of languishing waits for...
BYD Sealion 6 DM-i
