Results 21 to 30 of 36
- May 2019
- 1
May 10th, 2019 04:00 PM #21
- May 2017
- 2,128
- Jun 2005
- 3,774
May 11th, 2019 10:24 AM #23
- May 2017
- 2,128
- Sep 2016
- 93
February 16th, 2020 12:18 PM #25I have this PMS dilemma.
Yes PMS is very important 1k, 5k, 10k, etc or every 3 months, whichever comes first. failure to do so may void the warranty, Para sa sasakyan to diba? pero paano naman ang welfare ng owner if by chance hindi sya makasunod sa PMS?
Ano-ano ba ang mga considerations sa PMS?
Timing
- Can the car be scheduled 2 weeks prior due date?
- Can the car be delayed on scheduled PMS? if Yes then How many Days can be acceptable to be delayed?
- Living in a rural area may find hard time to meet Scheduled Date of PMS
Mileage or Odo
- Scheduled 1k km PMS (1st month) but odo is 1.1k km - This is just fine.
- Scheduled 5k km PMS (4th month) but Odo is still 4k km - This is just fine.
- Scheduled 10k km PMS (7th month) but odo is still 6.5k km - Are there any consideration for this?
Are this considerations are Nationwide Toyota implemented?
Thank you.
- 54,197
February 16th, 2020 11:59 PM #26
- Sep 2016
- 93
February 17th, 2020 08:22 AM #27
- 54,197
February 17th, 2020 08:47 AM #28
February 17th, 2020 10:25 AM #29
I just do PMS every 6 months don sa Avanza nang uncle ko (he's in the US)..
and basic change oil lang (regular oil lang gamit) walang add ons.. minsan 3T+ lang kada PMS sa casa to..
Then I follow the KMs reading pag major change.. like change fluids etc.
- Feb 2020
- 10
March 2nd, 2020 06:52 PM #30Normal PMS is every 5kms or every 6 months which ever comes first. 10kms for sythetic oils.
What is the main reason for 5kms change oil?
-It's to flush the deteriorated oil that might loose the viscousity that is bad to the engine and re-fill newer oil. Deteriorated oil will increase wear and tear if viscousity drops. But for synthetic oil, it deteriorates longer due to wider temperature range and properties that differs from base oil. Oil molecules having the same sizes compared to base oil that causes the effect of smoother performance than base oil. Thats why synthetic oil follow every 10kms change oil but change oil filter every 5k.
Why change oil on the 6th month even less than 5kms?
- The main reason is the same of 5kms, deterioration of oil. It might also looses viscousity and could damage the engine.
So if you want to extend the life of your car (especially the engine), invest in lubrications. Change oil earlier of recommended, the better but costly. Change oil beyond recommended, it will save you money initially but would cost your car in the future. Or just follow the recommended change oil every 5kms or 10kms and surely you will have longer life on your car.
Always remember that when you buy a car, PMS cost of the car must also be considered. Otherwise, don't buy a car and just use public transportation instead.
Blue-labeled Motolite Gold are factory-supplied OEM batteries with only 1 year warranty.
