Page 928 of 1549 FirstFirst ... 8288789189249259269279289299309319329389781028 ... LastLast
Results 9,271 to 9,280 of 15485
    Jan 2014
    #9271
    Quote Originally Posted by 2rm View Post
    ano po stock battery ng 2012 Innova G Diesel A/T? Size and Brand ? Thanks.
    it is 2sm yung brand nakalimutan ko na
    why naubos agad karga ng battery ng innova mo??
    Jun 2006
    #9272
    I dont know why 200 yon, maybe larger tires.
    personally 180 max ko, kahit sino mag post dito, 180 max ng vvti.
    #9273
    ^tried it before yup hanggang 180 lang ayaw na lumampas hehe vvti A/T user here.
    Dec 2009
    #9274
    I think the brand is Outlast. I changed my battery just this year. Mine is a 2010 model. Napansin ko lang medyo hard starting na sya around April this year so I ought to replace it in advance. Ayoko tumirik A/T pa naman unit ko. Motolite Enduro pinalit ko. Ung isang unit ko before Enduro tumagal ng 5 years.
    fiber_optic
    Jan 2014
    #9275
    Quote Originally Posted by shibby75 View Post
    It's in my owner's manual maxspeed ng 2kblah
    d4-d engine is 180kph
    Jan 2014
    #9276
    Quote Originally Posted by fiber_optic View Post
    fiber_optic
    Sir anong motolite 3sm or 2sm??
    Saakin 3sm gamit ko sa innova pang 2yrs lang mas advisable daw
    yan para di hard starting sa morning
    Sep 2014
    #9277
    Hello everyone!! I'm new to this forum, and as you may have guessed, I am not from the Philippines. I do, however, live in the Philippines and own a 2009 Toyota Innova.
    I like the van a lot, and it has given me few problems.
    My issue is this: My rear aircon fan is not coming on. I use the switch to turn it on, but get nothing. It worked fine until a couple of days ago. The front aircon unit is fine. I don't have a clue about this van's equipment as it is VERY different from anything I have owned before.
    NOTE: I have had the front aircon unit serviced as it had stopped working. Now, the back is not working.
    My questions:
    1. Does this van have two airconditioning units, or simply two fans?
    2. Where is the second fan located?
    3. Is there also a second filter?
    I appreciate any and all help you can give me on this, as the dealer is VERY expensive just to look at the aircon.
    Thank you!
    #9278
    Quote Originally Posted by kanofortune View Post
    My questions:
    Thank you!
    a 2009 innova is definitely out of warranty by now. that means, you can have it serviced anywhere..
    you can try the aircon shops at banawe st. in quezon city. it's the aftermarket auto mecca. prices there are significantly lower than dealer prices by up to 50%, maybe more.
    to answer your questions:
    1. the van has only one aircon, i.e., one compressor, one heat exchanger (in front of the engine), one filter and drier. but it has two fans.
    2. the first fan is under the dashboard. the second fan is behind the right rearmost panel. it can be accessed by removing said panel. alas, you also have to remove the folding right rearmost seat to do so. it's not a complicated affair, but takes a fair amount of muscle. the bolts to remove are visible and accessible.
    3. someone here said a while back, that there isn't a filter for the rear fan, but a little ingenuity can remedy that.
    before ripping into 'er, please check the fuses first. your problem might simply be a case of busted fuse. a good auto electrician can help you with this, with only minimal fee, as all it takes is a few minutes and very little elbow grease.
    good luck.
    Dec 2009
    #9279
    Quote Originally Posted by crosswind View Post
    Enduro sir ung puti 2sm lng gamit ko. Mas ok ung enduro kesa sa gold based on my experience.
    fiber_optic
    Sep 2006
    #9280
    hey guys, i have a 2012 D4D G AT. before when I fill up, the trip computer gives an average distance of around 415-430km range, actual fuel consumption is around 10-11km/L.
    Now it only returns 370-385kms. actual fuel consumption based on manual computation is around 8.8-9km/L. any tips to improve mileage again?
Toyota Innova Owners & Discussions [continued 3]
