Page 875 of 1549 FirstFirst ... 775825865871872873874875876877878879885925975 ... LastLast
Results 8,741 to 8,750 of 15485
    #8741
    considering just how thin the stalk of the light switch is, i find it difficult to imagine having no relay for the headlights.
    relays usually are easy to service... pull out the old, push in the new.
    Oct 2013
    #8742
    Not sure paps kung may high side driver ang headlights natin, pero sa per service diagram, wala talaga. Horn lang ang may relay, aircon, power outlet socket.
    Aug 2010
    #8743
    ma void ba ang warranty kung magpakabit ka ng relay for both headlight?
    Oct 2013
    #8744
    Depende sir sa kung paano mo ikakabit yung relay, kung wala ka puputulin or i-splice, hindi yan mavoid, pero hindi fool proof ang relay, better test mo rin yung relay for several hours kung umiinit ba masyado yung coil nya sa loob or hindi, kasi may mga relay na hindi pang matagalan na naka-on dapat.
    And need mo rin maglagay ng fast switching diodes sa supply ng relay, not ordinary rectifier diodes para hindi affected yung 12V line mo ng mataas na transient and back EMF.
    If ever ako ang gagamit ng relay sa headlight, yung headlight terminals ang gagamitin ko para sa terminal ng relay para plug-in sa modification.
    #8745
    Hi! Any idea how to reattach the front wiper washer nozzle? I was driving in the rain yesterday and i activated the washer. I noticed that the passenger side was not working. Popped the hood and noticed the bottom part of the washer was disconnected. My fingers are too big to reattach it. Any inputs? Thanks in advance.
    #8746
    Quote Originally Posted by viper2lt View Post
    can you find another set of smaller caliber fingers? if not...
    many nozzles are removed from the hood by turning it 90 degrees. maybe you can try this, then re-connect the tubing.
    pulling the tubing out thru the nozzle's hole may need some alambre and a little ingenuity..
    good luck.
    Jan 2013
    #8747
    Hello tsikoters.. may tanong lang ako.. san ba nakakabili ng knn drop-in air filter na para sa Innova na mas mura? yung mga napag tanungan ko kse 5.5k kay speedlab at c34x4 at 5.3k naman kay High Octane sa banawe.. salamat tsikoters..
    #8748
    Quote Originally Posted by homhomnova View Post
    pm sent sir. thanks
    #8749
    good luck.
    Ok na po. I went to banawe to look for one but they said they don't carry small items like these. Sa casa lang daw meron. A freelancer then looked at the part and repaired it. I tried to remove the nozzle by turning it but it wouldn't give so i didn't force it. It was held by 2 clips thanks for the tips. I appreciate it.
    Oct 2013
    #8750
    You can call casa for the part number, mura lang yan, baka nga di yan mag 300 pesos pair.
Toyota Innova Owners & Discussions [continued 3]
