Results 3,631 to 3,640 of 15485
June 26th, 2012 05:24 PM #3631
Hi Mile2, do you have experience cleaning the MAF? required po ba ito for cleaning? Ano po ang nangyayari pag madumi itong MAF? is it possible na marumi ito without the engine lights ON?
how much din po ang gastos pag nasa 100,000 kms? Replace V-belts, timing belts and tensioner bearing?
TY
- Jun 2012
- 12
June 27th, 2012 12:47 AM #3633Hi, magkano po b bayad s 10k km PMS mineral / fully synthetic oil? And saan po magandang service? Thank u po...
Saka nga po pala matagal ako umabot ng 5k km kasi ndi ko po masyado gngamet innova..almost 7 months yata from 5km to 10km..
2010 innova E M/T GAS
June 27th, 2012 09:59 AM #3634
If you want to clean the MAF sensor, just spray it with Electronic Contact Cleaner and don't touch it, as it is very fragile the reason why it is enclosed very far from the air hole opening. Just spray a little then let it sit for few minutes then spray a 2nd one to drip the dirt then screw it back on the air intake. Cleaning MAF sensor is not much nescessary as long as you keep good maintenance of your air filter. Usually MAF cleaning is done together with throttle assembly cleaning and with same procedure of just spraying contact cleaner solution.
Note: Engine malfunction light indicator is not always due to MAF sensor malfunction. You will need an OBD scanner to decode engine malfunction lighted.
Timing belt - For VVTi there's no timing belt, it has timing chain that would last till your engine drop dead. No timing chain replacement maintenance for VVTi.
if you're having 100K Kms PMS it would be wise to replace the serpentine belt that drives your fan/alternator/aircon/power steering.Last edited by Mile2; June 27th, 2012 at 10:02 AM.
June 27th, 2012 11:33 AM #3635
June 27th, 2012 05:11 PM #3636
June 27th, 2012 05:25 PM #3637
Mga ka-innova, di ba yung upuan sa 3rd row, may parang belt na naka-attach yung hook para masabit natin in case we need the space. Yung sakin kasi, napatid doon sa part ng upuan, di ko tuloy masabit yung upuan.
May alam ba kayo na gumagawa nito?
Maraming Salamat!
GLD
June 27th, 2012 05:38 PM #3638
June 27th, 2012 05:52 PM #3639
For a 7-seater under 1 million, the Suzuki Ertiga is definitely one of the best options — it’s...
Best car worth 1million and below
