Page 1486 of 1549 FirstFirst ... 13861436147614821483148414851486148714881489149014961536 ... LastLast
Results 14,851 to 14,860 of 15485
    Jan 2009
    #14851
    ahoy!
    i have question.
    my 2005 innova diesel timing belt warning light flickers for a minute or so, upon starting the engine from cold.
    then it disappears.
    i had my timing belt replaced about a couple of thousand km ago, at the casa.
    what does the flickering mean?
    Probably it wasn't reset properly.
    Resetting the T-BELT indicator means setting a new distance (in X * 10,000Km) for the next replacement. So, if you want the indicator to warn you after say, 150,000km from now, set X to 15.
    This is done using the TRIP button and ignition key combo to get to the setting. There are numerous YouTube videos of it for either the Innova or Hilux.
    Dec 2019
    #14852
    Also for the Fortuner.
    Here's how to reset it doc..
    Feb 2019
    #14853
    I don't think dr. d odometer had reach 150,000km yet because T-Belt sign will remain on at all times after ignition.
    Jan 2009
    #14854
    He had it replaced previously. I don't know whether if the T-BELT lighting up is what prompted him to change it or not, but the counter should've been reset after replacement. It doesn't matter if the T-BELT is lit or not.
    ahoy!
    i have question.
    then it disappears.
    Aug 2013
    #14855
    Finally decided to replace clutch for 2014 Innova 2.5 since it's already sliding. Max speed is 120kph, ODO of 160k kms.
    Any tips here or maybe a good deal within Pasig area?
    Aisin daw gamit ni Toyota? Anyone tried Exedy?
    Someone quoted me 12K for Aisin kaso sa Antipolo pa cia.
    ASAP sana while hindi pa kinukuha ni wifey bonus
    #14856
    it's not a consistently-on light.
    upon starting from cold, it sometimes just flickers a bit for a minute or so, then disappears.
    although i had no timing belt issues before, i had the casa replace the timing belt at about 130K km, as a matter of pms
    #14857
    Quote Originally Posted by Vann-O View Post
    tell us what happens, po.
    i am also thinking of replacing my clutch. medyo matigas (na) kasi, compared to our other innova's.
    Aug 2013
    #14858
    Max speed is only 120kph now unlike nung bago pa umaabot 160kph. And sometimes bigla na lang bumabalik sa "neutral" while in "segunda" on its own creating a "thug!" sound kaya magugulat ka nlng.
    Also, meron din cia vibration issue sa manibela *100kph though sa suspension/gulong na po cgro un.
    Dec 2019
    #14859
    is it also jerking?
    Aug 2013
    #14860
    is it also jerking?
    No, sir. No other issue other than the specified above.
Toyota Innova Owners & Discussions [continued 3]
