Results 9,271 to 9,280 of 15485
September 6th, 2014 09:47 PM #9271
- Jun 2006
- 1,139
September 6th, 2014 10:47 PM #9272I dont know why 200 yon, maybe larger tires.
personally 180 max ko, kahit sino mag post dito, 180 max ng vvti.
September 6th, 2014 10:50 PM #9273
^tried it before yup hanggang 180 lang ayaw na lumampas hehe vvti A/T user here.
September 8th, 2014 12:41 AM #9274
I think the brand is Outlast. I changed my battery just this year. Mine is a 2010 model. Napansin ko lang medyo hard starting na sya around April this year so I ought to replace it in advance. Ayoko tumirik A/T pa naman unit ko. Motolite Enduro pinalit ko. Ung isang unit ko before Enduro tumagal ng 5 years.
fiber_optic
September 8th, 2014 10:01 PM #9275
September 8th, 2014 10:07 PM #9276
- Sep 2014
- 1
September 8th, 2014 11:40 PM #9277Hello everyone!! I'm new to this forum, and as you may have guessed, I am not from the Philippines. I do, however, live in the Philippines and own a 2009 Toyota Innova.
I like the van a lot, and it has given me few problems.
My issue is this: My rear aircon fan is not coming on. I use the switch to turn it on, but get nothing. It worked fine until a couple of days ago. The front aircon unit is fine. I don't have a clue about this van's equipment as it is VERY different from anything I have owned before.
NOTE: I have had the front aircon unit serviced as it had stopped working. Now, the back is not working.
My questions:
1. Does this van have two airconditioning units, or simply two fans?
2. Where is the second fan located?
3. Is there also a second filter?
I appreciate any and all help you can give me on this, as the dealer is VERY expensive just to look at the aircon.
Thank you!
- 54,198
September 9th, 2014 02:13 AM #9278a 2009 innova is definitely out of warranty by now. that means, you can have it serviced anywhere..
you can try the aircon shops at banawe st. in quezon city. it's the aftermarket auto mecca. prices there are significantly lower than dealer prices by up to 50%, maybe more.
to answer your questions:
1. the van has only one aircon, i.e., one compressor, one heat exchanger (in front of the engine), one filter and drier. but it has two fans.
2. the first fan is under the dashboard. the second fan is behind the right rearmost panel. it can be accessed by removing said panel. alas, you also have to remove the folding right rearmost seat to do so. it's not a complicated affair, but takes a fair amount of muscle. the bolts to remove are visible and accessible.
3. someone here said a while back, that there isn't a filter for the rear fan, but a little ingenuity can remedy that.
before ripping into 'er, please check the fuses first. your problem might simply be a case of busted fuse. a good auto electrician can help you with this, with only minimal fee, as all it takes is a few minutes and very little elbow grease.
good luck.
September 9th, 2014 08:09 AM #9279
September 9th, 2014 01:54 PM #9280
hey guys, i have a 2012 D4D G AT. before when I fill up, the trip computer gives an average distance of around 415-430km range, actual fuel consumption is around 10-11km/L.
Now it only returns 370-385kms. actual fuel consumption based on manual computation is around 8.8-9km/L. any tips to improve mileage again?
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
