Page 2 of 1549 FirstFirst 1234561252102 ... LastLast
Results 11 to 20 of 15485
    Jan 2011
    Hope this helps. Pasig allows outside oil basa orig. Pasig even alllows imported OEM toyota oil filter 90915-yzzd1 from US but driver forgot to bring it. Makati doesn't allow outside part.
    Had my 20K pms in Toyota pasig today 2010 innova a/t gas
    told them NO additve/fuel treatment and engine flush.
    Brought our own 6 quartz of Mobil 1 10w30 oil and ikh20 iridium plugs from US
    20K labor 1148
    oil filter 426
    drain plug gasket 28
    misc 113
    sand paper 25
    Total is P1740
    Jan 2011
    Toyota Pasig 20K PMS Innova Gas A/T
    Pasig allows orig oil, Makati doesn't
    Brought own Mobil1 10w-30 oil and IKH20 iridium plug
    Service Advisor was nice and accomodating
    Our driver politely told him NO engine flush, wash(baka ma short circuit pa),engine detail(linis pa naman makina), fuel treatment(merong techron naman ang caltex gasoline), car care kit(grease sa door hinges).
    20K labor 1148
    Oil filter 426
    Drain plug gasket 28
    Misc 112
    Sand paper 25
    Total P1,740
    Jan 2011
    20K labor 1148
    Oil filter 426
    Misc 112
    Sand paper 25
    Total P1,740
    Dec 2009
    Vic2rem sino service advisor mo? Ako si Andrew Fernandez. Right ka very accomodating mga SA ng Toyota Pasig. Nagdadala rin ako oil (Royal Purple 10w x 30) oil filter sa casa na ko kumukuha.
    does anyone know how to remove the rear view mirror?
    Mar 2011
    Quote Originally Posted by lowrider17 View Post
    share lang mga paps. it is our 2nd tym going to baguio. 1st dala namin ung revo and ngayon ung innova namin. napapansin ko lang ibang iba tlga hatak ng revo sa innova pagdating sa mga steep road. parang under power ung innova compare sa revo... isa pa experience ko sa slex cruising at 150kph bakit parang may amoy na nasusunog sa a/c.tumigil kami sa gas station to check pero wala naman.. everything seems fine. tapos sa nlex sinubukan ko ulit after reaching 160kph ganun na naman ulit pero kpag chineck naman namin ung engine ok naman... may naka experience na ba nito?By the way FC namin satisfied naman ako 800kms=more or less 65liters of diesel
    Ok lang sir yan, ganyan din malimit maexperience ko kapag more than 100 kph na takbo. Nagaactivate lang ang mga seatbelt tensioner nyan at ung abs. Kaya yung naaamoy mo, fumes or gas pero di naman delikado na maamoy yan, inixplain yan sir sa manual.
    Quote Originally Posted by brench View Post
    ah yun ba yun sir, nabasa ko sa manual akala ko naman mag activate lang yun in an accident kasabay pag deploy ng airbag.nagulat lang family ko kasi early morning kami umalis at bakit daw ganun amoy. anyway thanks sir Brench
    do you know how to safely remove the rear view mirror of an innova? is there a clip there somewhere?
    Mar 2011
    mga bos, ano ba maganda brand ng alarm with central locking na compatible para sa mga innova?and also how much kaya usually ang prices, sa net kasi,prices ranges from 1300 and above kaso baka di ito compatible sa innova and probably wala pa dito ang labor cost...thanks guys..hope to hear from you soon..
    Jan 2011
    Yesterday my 2010 innova diesel had its 15,000 km maintenance check-up. When I picked it up the SA just handed me the billing statement and did not mention any problems or findings. Just the usual oil change, tune up and inspection he said. Since I was in a hurry I did not go over the details of the billing.
    When I finally had the chance to read the details of the billing at home I noticed there was an entry in the bottom which reads " Recommendations: FRT RH Shock Absorber leak".
    Anything to worry about this finding? Tried calling the SA but he is unavailable.
    Covered ba ng warranty ang shock absorbers?
    Has anybody encountered this same problem with their unit?
Toyota Innova Owners & Discussions [continued 3]
