Results 9,551 to 9,560 of 13229
February 25th, 2009 07:30 PM #9551
Ok I understand your case. In the contrary, I mean in my case, when I use the ACs in parallel, that is when I travel south to north together with my wife, kids and yaya, I observed a significant fuel consumption which is higher than using only the front AC. Anybody here observed this as well? Or are we just saying here about the AC maintenance which should be operated always in parallel, irregardless of the fuel concern.
- Feb 2008
- 898
February 25th, 2009 09:15 PM #9552for those of you who have seen the stock stereo of innova (back portion), are there two rca out. I actually intend to place an amplifier....
February 25th, 2009 10:05 PM #9553
Actually, its because your compressor is always engaging more frequent when only the front A/C is on, it is trying to cool the entire cabin and your thermostat is saying that cooling is not enough and will again engage your compressor, whereas if your rear A/C is on in tandem you will actually be cooling your entire cabin faster and the lesser the compressor being engage...less engage...less engine load
About the damp cloth smell, if you use only the front A/C, you are actually cooling half of your cabin, and the other half is less cool and getting hotter in the rear end. Guess what? condensation can leave mist of water on your carpet and seats...and molds will grow ...then the damp cloth smell.
February 25th, 2009 10:12 PM #9554
February 26th, 2009 12:59 AM #9555
According to what is being posted in forums, turning off the compressor and setting the fan settings into "high" a few minutes before arriving in the destination is best, right?. Well, I get a hint of damp cloth smell after say five minutes in this kind of setting (recirculate on). The smell gets stronger if the recirculate is turned off.
Also all these talk of molds is getting me worried. Right now, my seat cover are those leatherette type. Do you think molds/mildew will grew inside, since they less breathable than the cloth type seat cover? I also carry stuffs in the back like umbrellas and some small cabinet sample boards.
Also how to prevent molds from perpetuating inside (not that I see any)? Turn the rear a/c on also at all times ?What about the temperature setting in front (mine is the auto climate control type)?
- Feb 2008
- 898
February 26th, 2009 06:51 AM #9556
February 26th, 2009 07:31 AM #9557
February 26th, 2009 11:23 AM #9558
Yes, do turn on the rear A/C at all times, If you have auto climate front then that's well good.
Clean and dry cabin will help prevent molds, if you have garage just let small window openings even once a week to recirculate air inside the cabin and dries up damp areas. Molds don't grow on dry surface.
February 26th, 2009 11:39 AM #9559
Re-arrange ko lang Bro.
*attyallanlatras
For older Innova's prior to 2009 facelifted version.
1. Pull out the 3 control knobs of the AC
2. Remove 2 screws holding the center panel.
3. Pry out the center panel exposing the 2 screws in front of the bare HU. Unscrew them. Pull out your HU. Done.
Someone, already posted a wiring diagram/back panel of the stock Fujitsu HU in this thread, I just could not sort it out where I have put mine which I have downloaded from here. Kindly try searching it in this thread.
I have used that diagram to install additional 4 Bose bookshelf type active speakers
- Feb 2008
- 898
February 26th, 2009 11:55 AM #9560I have seen the post of the rear of the stock stereo of Innova. Indeed walang rca out. I was told that if I place a converter para may rca out sya before installing an amplifier. posible daw na yung converter will be the source of static noice...is this so? has anyone experience that already? I wasnt kasi na mag-install ng jbl amp and replace the front speakers with jbl separates, without subwoofer muna. Will I be doing it right?
Most likely were the same problem ,guyz can anyone can tell especially those people resolved the...
4g15 rare Idle motor (servo)
