Page 57 of 60 FirstFirst ... 7475354555657585960 LastLast
Results 561 to 570 of 594
    #561
    Quote Originally Posted by luis_ View Post
    Pano ba tamang teknik... speed up to 80 then bitaw wait mag 75 then tapak ulit pabalik 80 or steady sa pedal?
    Quote Originally Posted by airolynx View Post
    No worries sir. Same question as the good sir above this post, how did you do it? Id like to try that on my Accent Hatch. Hehe
    From a stop, I step on the accelerator with moderate pressure to speed up the shifting until the highest gear (4th gear in my case), but not too much pressure - just enough to get it to shift at 2000-2500 rpm.
    Once I'm in my cruising speed of around 80 kph, I put as little pressure as possible on the accelerator. Think of it as squeezing a shampoo bottle as lightly as you can so that you only use a minimal amount of shampoo. I find that this is better than stepping on the gas hard, then coasting, then stepping hard again.
    On uphills, I try to maintain the same minimal pressure, but there are times that the speed drops to 60 kph which isn't very efficient anymore, so I apply a bit more pressure even if it means I'll have to rev a bit more. This is still more efficient than crawling at a low speed. On downhills, I still apply the same minimal pedal pressure as on a flat road, which means the car goes faster than 80 kph. I use that momentum so that I carry speed when I traverse the next uphill.
    When approaching toll booths, I coast from as far as 500-750m away so that by the time I reach the queue, I'm only doing 40-60 kph so I minimized my braking and hence my fuel use.
    Just a reminder though, it's a really, really boring drive to stay at 80 kph even if the road is completely empty. Everyone else will just overtake you. I find this kind of driving impractical since it makes my 2 hour trip a 3 hour trip, all for a few pesos of savings. I just do it to see how efficient my car can go, but it definitely isn't my kind of driving.
    Apr 2008
    #562
    Lately my FC has been decreasing on the Altis (1.6L m/t). I'm doing 8.5 to 9.5km/L in the city and around 10.5km/L mix. Used to be +1km/L better and i'm attributing this to the summer heat and the traffic on my daily route which has gone worse... which is taking its toll on my patience so i'm heavier on the gas pedal too.
    Same here. I usually get a pretty consistent 8-8.5km/L with the Revo using the full tank method. My last full tank yielded only a comparably dismal 6.95km/L. I'm blaming it down to the increased aircon use. Its almost always at maximum nowadays and the rear A/C is almost always open when there are additional passengers. Are there any other factors in the engine that may cause additional fuel consumption?
    Jan 2014
    #563
    ^^thanks.
    I always thought that pitik pitik was better than a la cruise control
    #564
    ^^thanks.
    Cruise Control is different - it adjusts throttle input to maintain speed. For example, if you maintain the same pedal pressure to stay at 80 on a flat road, you will inevitably slow down to about 60-70 on an uphill. With cruise control, it will increase throttle input to maintain 80 kph on an uphill.
    Pulsing the accelerator works well in light city traffic though. Just give enough throttle to make it to the next bottleneck or stoplight intersection, then rinse and repeat for every cycle of clear and clogged roads.
    May 2015
    #565
    Avanza 1.3E AT 2014
    7.5km/L
    Commonwealth -> Katipunan -> BGC weekdays route ko
    highest FC ko so far 8km/L
    Avanza 1.3E AT 2014
    7.5km/L
    #566
    Just got back from bicol trip. I got 15.3 km/L on the midnight run on the way there with 4 adults and 1 kid. Pero on the way back it went down to 10.6 km/ L, factors are the extra weight going home. 1 adult snd 2 sacks of rice , ++ etc, and the slow down in the quezon area in the afternoon. Also using avanza 1.3. Normal city driving is only 8.5 km/l around qc.
    #567
    Make & Model: Innova 2012 E DSL MT
    Fuel: Unioil (same station and pump)
    Method: Full Tank (matic)
    FC1: 15.015 Km/L (172.1 Km)
    100% highway
    Average of 80 Kph or 2K rpm
    Dual aircon & Radio on
    3 adults
    medium luggage
    FC2: 6.785 Km/L (23.3 Km)
    100% city, medium to heavy traffic
    4 adults
    no luggage
    FC3: 13.284 Km/L (176.3)
    98% higway, 2% city
    Average of 100 Kph or 2.5K rpm
    7 adults, 2 kids
    heavy luggage
    100% highway
    3 adults
    medium luggage
    4 adults
    no luggage
    98% higway, 2% city
    7 adults, 2 kids
    heavy luggage
    Oct 2014
    #568
    ^^thanks.
    What if the car is moving at 100KPH then cruise/clutch down, para bumaba RPM.. then gas ulit, then cruise/clutch down ulit?
    #569
    Lowest rpm does not mean lowest consumption.
    The fact that you will have to repeatedly prod the pedal will consume more fuel as opposed to a steady input.
    #570
    Bakit ganito ang FC na nacacalculate ng aCar app? Sa mga gumagamit nito, Anong need ko baguhin to reflect the correct FC? Thanks
Toyota Fuel Consumption Database
