Results 1,251 to 1,260 of 3575
- Dec 2011
- 14
October 15th, 2012 10:54 AM #1252
For those with Gen 10.5 Altis models (using the ZR series engines already) and want to get their oil changes done outside of Toyota, try checking out on getting your own oil filter removal wrench for the canister-type design oil filter of the ZR engine. I remember cjv_justice mentioning that the mechanic had a hard time removing it with the standard oil filter wrench and could risk cracking the housing. I searched on the web and asked a cousin of mine to hand carry this Manila for me when she visits:
This is how it looks with the oil filter housing attached:
It costs USD 18.22 on Amazon and fits other Toyota models with the same oil filter design. I'll post feedback on this once i have it with me and give it a try on my next oil change.
October 15th, 2012 03:44 PM #1253
*vinj
Does that serve as replacement for the existing hard-to-remove cap?
- Dec 2011
- 14
October 15th, 2012 05:15 PM #1254Hi guys, I'll be going for my (Altis 1.6V) 10k service at toyota san fernando tomorrow. Do you have any advice, do's and don't's? Any idea what toyota does for 10k service? Do you have your tires rotated at 10k?
October 15th, 2012 05:19 PM #1255
October 16th, 2012 12:22 AM #1256
Thank goodness for this product. I hope it becomes locally available for workshops acquire this tool.
* all - I'd like to ask if our cars are included in this latest recall advisory from Toyota?Last edited by cjv_justice; October 16th, 2012 at 12:25 AM. Reason: edited quote
October 16th, 2012 12:53 AM #1257
October 16th, 2012 09:28 AM #1258
It's an adapter to the existing cap. On the second picture, you'll see how it attaches to the oil filter housing cap (the black part).
If you have an Amazon account, you can order it online then have it delivered to a relative or to a courier who ships to the Philippines.
x2 on not going for the miscellaneous services Renzo mentioned. It's basically an oil change, check suspension, and i think the spark plugs are also replaced along with a tire rotation. You also have the brakes cleaned and sometimes they offer to use the spray-on brake cleaner, if the price is okay then this is good as i prefer using spray on brake cleaner over the pressurized air and liha method (or you can bring your own like the 3M brake cleaner spray you can get at Ace Hardware).
Does anyone know if the ZR uses copper or iridium plugs already (i saw this on the specs in the owner's manual before).
October 16th, 2012 10:15 AM #1259
This is the official statement from Rommel Gutierrez, VP Corporate Affairs of TMP:
“In line with our commitment to produce safety and quality, Toyota has initiated a Special Service Campaign (SSC) for specific Camry, Corolla, RAV4, Vios, and Yaris models produced from 2006 to 2010.
For the affected vehicles, the sliding electrical contact point in the driver’s side Power Window Master Switch may experience a “notchy” or sticking feeling during operation which causes the button to get stuck. If vehicles are serviced in non-Toyota dealer and commercially available lubricant is used, melting of the switch assembly may occur.
As a preventive measure, we will inspect the Power Window Master Switch and apply specialized grease or replace specific component if deemed necessary, at no cost to the customer. This program will be offered at all Toyota dealers only.”
- Jan 2009
- 31
October 16th, 2012 11:47 AM #1260any idea on how much the 40,000 PMS cost? thanks ( from what I know around 10??? am I correct???)
I dont think So
Need help choosing a bigger ride for my growing...
