Results 1 to 10 of 16
- Feb 2018
- 65
September 20th, 2018 03:15 AM #1Hi guys,
After switching from civic fd to crv, I now have a camry 2008 2.4v. The car is good but I have a few problems... Maybe someone with similar
experience can help me....
1) the suspension is very soft and soundless however at low speed and going over rough road, I hear a bogbogbog sound from drivers side underneath. I can also hear a single tuk tuk noise when I am turning and going uphill..
2) people who has lowered their camry, does it effect the ride? I love the comfort of the car and wouldn't want to change it...
3) there is a strong rattle from the drivers side seat control area.. Any anyone has this issue?
- Apr 2008
- 6,235
September 20th, 2018 08:32 AM #21. Perhaps you can try replacing your shocks and stabilizer links.
2. Never been a fan of lowering and don't have a Camry, so cannot comment much on this one. But generally, decrease in ride comfort due to lowering depends on the method. "Putol method" or lowering springs?
3. What seat control area? The door? Or the seat mismo?
Sent from my SM-G900I using Tapatalk
- Feb 2018
- 65
September 22nd, 2018 03:16 AM #3HI,
This is turning out to be a mission.... So I put new rear shockers kyb. New stablink. New sway bar bushings and checked each and every component of the rear suspension. After test driver, the noise is still there... It's like when you go over humps, you can hear a "dukkk" sound from passage rear side. And on rough roads, this sound becomes contineous.... In the past I have had this sort of noise from the front due to faulty rack and pinion but obviously there is no RnP at the rear.....
My mechanic said he has checked everything but can't find any fault....
- Apr 2008
- 6,235
September 22nd, 2018 07:59 AM #4
- 54,198
September 22nd, 2018 09:03 AM #5i would check the rubber bushings.
i would also check the tambutso mountings.
it might be the exhaust pipe we are hearing.
- Jul 2009
- 3,604
September 22nd, 2018 10:32 AM #6
September 22nd, 2018 02:17 PM #7
After replacing the under chassis bits and suspension parts ... It might just be a loose tool bag, jack, or handle ...
- Aug 2008
- 142
September 23rd, 2018 09:42 AM #8I used to have a Camry 2.4V, had knocking sound from the rear suspension, turned out to be a bad shock mount.
That Camry’s suspension is very soft...comfortable but tends to bottom out. Used to keep hitting the front chin on parking stops and floor pan going over humps. Personally, I would put firmer shocks rather than lower the car as the stance is already quite low. But that’s just me.
- Feb 2018
- 65
September 23rd, 2018 06:54 PM #9Guys been to 5 mechanic but no one can find the problem.
Today 1 mechanic has seems to find the problem but I still want to double check.... Could this be the problem??? Or is it suppose to be like that to give some movement ability?
Camry 2008 lower arm bushing movement - YouTube
- 54,198
September 23rd, 2018 09:58 PM #10it is usually easy.
have the car lifted via its body, such that the suspension hangs.
then shake the various components with your hands, and screwdriver-wedge everything, just like in the video.
as diehard suggests, check the shock mounts. shake the shock and see if it is loose and/or makes a noise. it should not be loose, nor should it make a noise.
try it yourself, sir. there's nothing like getting one's hands dirty.
good luck.
One can only hope.
