Results 1 to 4 of 4
- Nov 2008
- 15
September 10th, 2009 12:17 AM #1hi guys. i need your help pls. during the past few days its raining a lot because of typhoon labuyo. for 5 straight raining days, i noticed my carpet is soaked in water. my bro-in-law applied "masilya" on the firewall and it was fine. but after a month water gets inside the driver side. i checked the rubber/plastic (where wiper is attached) it has a space/gap compared to the other side which is sealed. is this the culprit? if not,what is it?where can i have this checked? thanks a lot
September 10th, 2009 01:32 AM #2
Put some water in it and see were does the water goes. check also your windshield rubber for leak.
- Nov 2008
- 15
September 11th, 2009 03:58 PM #3thanks sir for the reply. i think there's something wrong with the firewall here's how it looks like:
http://s956.photobucket.com/albums/a...elacruz1/seli/
i think i know the culprit, the firewall has a small tear on it. what do you suggest would i need "masilya" or silicon gasket to cover it up. thanks guys.
- Oct 2006
- 29
October 9th, 2009 04:22 PM #4I suggest you use silicone.. the flexibility of silicone is more appropriate in the car body's vibration...mine have same problem 2 months ago, culprit was the wiring rubber penetration cracked. This is found under the passenger side plastic fender so i have to remove the fender and apply silicone on the cracked rubber..now its good as new (just used the common silicon used on glass windows and it works fine)
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
