Results 1 to 10 of 16
- Apr 2009
- 6
July 31st, 2009 11:55 AM #1Guys I have a question, I bought this car last April and 2 weeks ago I had a change oil. What are the things I have to know in car maintenance. I have no idea its my first time to own a car. Pls. give me tips naman like Timing belt when to replace, iyong radiator, muffler, battery may nilalagay diyan di ba? Co-employeer of mine offered me 4 liters of fully synthetic oil (daw) for 1500 only. Just don't know kung may halo. Pero he is insisting na puwede raw iyon sa 97 model car. Sabi kasi nung sa shell na mekaniko pag old cars daw di na puwede synthetic. Is it true na di na puwede and full synthetic for old cars? TIPS PLEASE
July 31st, 2009 02:56 PM #2
I'd suggest sticking to regular mineral oil (20W-40) and just change your oil every 5,000kms. The thicker oil is suggested for older car as there are lesser chances it will leak out through the old gaskets in your engine.
As a matter of precaution, change your timing belt (use an original timing belt then for the tensioner bearings, go for the Koyo brand). Change all your fluids (brake, coolant, gear, PS) and your fuel and air filters as well, clean the brakes, check the belts, hoses, underchassis, etc. A compression test can also help to check of your engine is in a healthy state.
- Apr 2009
- 6
- Dec 2009
- 1
December 1st, 2009 06:21 PM #4
December 1st, 2009 07:11 PM #6
December 3rd, 2009 03:16 AM #7
Easiest car to maintain due to its ubiquity. Any mechanic anywhere can service this car and its 2E or 4AFE engine. If you got the 2E carbed version, all you got to do is check fluids (oil, fuel, water, power steering and brake/clutch) and you're good to go. This engine is bulletproof, I once got home to Manila from Taguig in rush hour traffic not knowing that the alternator drive belt and water pump had gone bust, so I was literally driving with NO coolant and solely on battery power all the time. Buti nalang di ako naka aircon ehehe... For gas, just use premium gas as much as possible, pero kung tipid ka puwede rin E10, but go back to premium gas unless sinasadya mo sirain yung makina to make cause for an engine swap.
BTW the silvertop 4AGE engine of Initial D renown is a direct bolt-on to the AE101. Ahhhh, the wonderful sound of ITBs...
As for belts, I used Bando. Seems OK to me, mura pa timing belt *400.
- Jan 2005
- 157
December 7th, 2009 01:08 PM #8i was in a 7 hour standstill in Edsa during Ondoy and an additional 2 hours of driving.Maasahan talaga itong 12 year old Corolla ko kaya binili ko agad ng bagong sapatos hehe
December 7th, 2009 01:45 PM #9
If you have the Toyota 2E 1300CC motor most of the encounter problem on it are leak in oil seal . Its best to replace it with a good quality even more expensive . The cheaper ones rubber oil seal easy to harden that causes oil leak.
December 7th, 2009 05:57 PM #10
Mahal ang orig na oil seals (lalo na pag di ka sanay sa presyo ng piyesa ng sasakyan), pero matibay. Isang beses pa lang pinapalitan ang oil seals ng 2E ko after 16 years, and this is on a 140K kms na car. First owner ako kaya alam ko.
Toyota Sports 800 (1965 - 1969) behind the man at the start of the video. :nod: I wish car...
2025 Manila International Auto Show
