Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Results 61 to 70 of 134
    #61
    Quote Originally Posted by basti08 View Post
    Yup, and so I read nga. Makes the GLS-V still a gear higher I wonder will it also have a rear disc brake like the middle line Montero Sport???
    Nasa previous post. Drum brakes pa din rear nung 2.5.
    3.0 pala yung may tech upgrade. hmmm
    Softer ride na lang at matched na halos ng MS.
    #62
    Still matters so little.
    Making the fort 5speed
    looking at the gear ratio of the monty, looks like the monty just gained one low gear. It gained a first gear as opposed to the gear ratios of the fort where the low is higher than the low of the monty (low of fort is effectively 2nd on the monty)
    its like the fort is always using 2nd as the low gear which it can, given the amount of torque it has at low revs, specially the 3.0v
    the d or 4th is almost the same as the 5th of the monty. I believe the 4th of the fort is slightly higher than the 5th of the monty.
    i lost my gear ratio tables so cant check now
    id like rear disk brakes on the fort though
    Aug 2004
    #63
    New Spec-Up FORTUNER & HILUX available on Aug 25th.
    Here are the ONLY changes:
    -the 2.5L D4-d engine now includes a Variable Nozzle Turbo & Intercooler. Power is rated * 144PS (142HP) & has 343 Nm of Torque.
    *Available on all Fortuner diesel & Hilux G & E models.
    -A new 7" touchsreen with GPS & DVD is now standard.
    *Available on all Fortuner & Hilux G 4x4 models.
    *2.7gas & 2.5G Manual has "Navi read only"
    New colors available:
    Fortuner : White Pearl (+15,000)
    Hilux : Freedom White & Super Red
    New prices:
    Fortuner
    4x4 3.0V D4d A/T - 1,759,000
    4x2 2.5G D4d A/T - 1,484,000
    4x2 2.5G D4d M/T - 1,381,000
    4x2 2.7G VVTi A/T - 1,358,000
    Hilux
    4x4 3.0G A/T - 1,474,000
    4x4 3.0G M/T - 1,420,000
    4x2 2.5G M/T - 1,131,000
    4x2 2.5E M/T - 972,000
    Aug 2012
    #64
    SRP or All in?
    Sep 2005
    #65
    Sana palitan nila design ng taillight, at gawing disk brake sa likod.
  6. #66
    Quote Originally Posted by wilcats View Post
    New prices:
    Fortuner
    Hilux
    Wait, no torque upgrade to the 3.0L???
    #67
    Quote Originally Posted by cripple_rooster View Post
    No upgrade to the 3.0L.
    #68
    Teka wilcats, Aug 27th na today. Any confirmation to the rumors?
    Aug 2004
    #69
    good day wala pa dumating na 3.0 spec-up saamin. But most likely hindi sya kasama sa engine upgrade. Nakuha na kasi namin yun memo from TMP. so its final I guess. Sa Thailand lang talaga iyong upgrade. baka next year pa natin makita yan upgraded 3.0. haha
    #70
    New prices:
    Fortuner
    Hilux
    Was referring to this, wilcats. Confeermed yung 2.5 VNT?
LEAKED: Toyota to launch 2.5L VN Turbo Intercooler engine for the Fortuner and Hilux
