Page 10 of 14 FirstFirst ... 67891011121314 LastLast
Results 91 to 100 of 134
    Aug 2004
    #91
    Quote Originally Posted by truckster View Post
    Still matters so little.
    Making the fort 5speed
    looking at the gear ratio of the monty, looks like the monty just gained one low gear. It gained a first gear as opposed to the gear ratios of the fort where the low is higher than the low of the monty (low of fort is effectively 2nd on the monty)
    its like the fort is always using 2nd as the low gear which it can, given the amount of torque it has at low revs, specially the 3.0v
    the d or 4th is almost the same as the 5th of the monty. I believe the 4th of the fort is slightly higher than the 5th of the monty.
    i lost my gear ratio tables so cant check now
    id like rear disk brakes on the fort though
    that's a good point to make given na yung 3.0li D4D dishes out full torque fm. 1400 RPM, as opposed to the (peaky) Mitsu 2.5 DiD full torque fm. 2000RPM.....
    #92
    Just came from Toyota Makati. They had a unit there. It did have the hood scoop and intercooler. Leather seats na din pala. And the navigation HU. Output na lang ang pinag-uusapan.
    #93
    Quote Originally Posted by junerski View Post
    nasa dyaryo ngayon sa inquirer motoring section yung vnt fortuner... antabayanan na lang natin ang walang katapusang review between fortuner vs montero... vnt vs vgt... pati yung gps HU nila pagtapatin na rin.hehe
    upgrade na ba from FM? hehe
    #94
    Quote Originally Posted by parakitoJDM View Post
    Hindi na po peaky, VGT na din turbo ng 4d56 ngayon. 400NM nga sa MT version eh.
    Jan 2011
    #95
    diba pinaka unang labas ng fortuner nun 999,999 pesos?
    May 2005
    #96
    Quote Originally Posted by timrev View Post
    Back in 2005, the most affordable Fortuner is 2.7 VVT-i and it was around 1.27 M.
    Aug 2005
    #97
    Bakit mayroon na kayo? sa pasong tamo wala pa at sa manila bay...
    Quote Originally Posted by wilcats View Post
    Meron na po kami dito 2.5L spec-up. same na same lang po ng look sa 3.0 hood scoop lang talaga po dinagdag. But I'll take photos of the &" touchscreen
    #98
    Meron na rin sa Makati.
    Mar 2011
    #99
    Pag m/t very significant difference yan torque nila. Pero kung a/t ang usapan i factor mo din yung stall speed nya.
    #100
    Di rin ata. I think it was in the P1.5M+ range.
    IIRC 1.495M lang yung 3.0V D-4D nung lumabas way back 2005.
LEAKED: Toyota to launch 2.5L VN Turbo Intercooler engine for the Fortuner and Hilux
