Results 61 to 70 of 134
August 21st, 2012 10:51 AM #61
- Jan 2007
- 43
August 21st, 2012 04:21 PM #62Still matters so little.
Making the fort 5speed
looking at the gear ratio of the monty, looks like the monty just gained one low gear. It gained a first gear as opposed to the gear ratios of the fort where the low is higher than the low of the monty (low of fort is effectively 2nd on the monty)
its like the fort is always using 2nd as the low gear which it can, given the amount of torque it has at low revs, specially the 3.0v
the d or 4th is almost the same as the 5th of the monty. I believe the 4th of the fort is slightly higher than the 5th of the monty.
i lost my gear ratio tables so cant check now
id like rear disk brakes on the fort though
August 21st, 2012 04:28 PM #63
New Spec-Up FORTUNER & HILUX available on Aug 25th.
Here are the ONLY changes:
-the 2.5L D4-d engine now includes a Variable Nozzle Turbo & Intercooler. Power is rated * 144PS (142HP) & has 343 Nm of Torque.
*Available on all Fortuner diesel & Hilux G & E models.
-A new 7" touchsreen with GPS & DVD is now standard.
*Available on all Fortuner & Hilux G 4x4 models.
*2.7gas & 2.5G Manual has "Navi read only"
New colors available:
Fortuner : White Pearl (+15,000)
Hilux : Freedom White & Super Red
New prices:
Fortuner
4x4 3.0V D4d A/T - 1,759,000
4x2 2.5G D4d A/T - 1,484,000
4x2 2.5G D4d M/T - 1,381,000
4x2 2.7G VVTi A/T - 1,358,000
Hilux
4x4 3.0G A/T - 1,474,000
4x4 3.0G M/T - 1,420,000
4x2 2.5G M/T - 1,131,000
4x2 2.5E M/T - 972,000
- Aug 2012
- 24
August 21st, 2012 05:00 PM #65
Sana palitan nila design ng taillight, at gawing disk brake sa likod.
August 27th, 2012 05:06 PM #69
good day
wala pa dumating na 3.0 spec-up saamin. But most likely hindi sya kasama sa engine upgrade. Nakuha na kasi namin yun memo from TMP. so its final I guess. Sa Thailand lang talaga iyong upgrade. baka next year pa natin makita yan upgraded 3.0. haha
August 27th, 2012 05:22 PM #70
Will wonders never cease with Motolite? Ha ha.
