Results 11 to 20 of 32
April 15th, 2011 07:54 AM #11
a bad ignition coil will make too much radio frequency interference. you can confirm this by running your engine and tune in to amplitude frequency (AM) on your radio. scan through the bandwith and it usually come up and you can hear it from the speakers if there is too much ignition leak.
- Jul 2010
- 166
April 18th, 2011 09:43 AM #12sa mga reply nyo po sir mukhang okay naman po yata ignition coil ko, siguro po ang problem ko ay sa carb, kung sakaling lakihan ko yung primary jet ko from 101 gawin kong 115? wala po kaya magiging problema?
- 54,198
April 18th, 2011 09:10 PM #13
- Jul 2010
- 166
April 18th, 2011 10:03 PM #14hindi ko na nga po alam gaagwin ko e, okay naman tunog ng makina, hindi palyado. wala ring problema sa start, one click lang andar na makina. okay din naman clutch lining at pressure plate. nagagamit ko naman ng long distance. yun lang talaga problem ko mahina sa arangkada, pag nasa expressway kaya naman tumakbo ng mabilis, yun nga lang medyo matagal. kumbaga hindi ngreresponse agad pag biglang tapak sa gas. madalas ako mabitin sa overtake. huh!
April 19th, 2011 06:53 AM #15
- Apr 2009
- 1,902
April 19th, 2011 06:59 AM #16In my case, biglang namatay yung makina ko after running past 140 kph sa Slex.
Namatay siya nung pag-exit ko.
Tapos hirap mag-start pero bagong palit ang starter (easy cold starts).
Hirap siya mag-start pag mainit ang makina.
Ignition coil din po kaya ito?
Engine is carburated Mazda B6 single cam (1600cc)...
April 19th, 2011 07:42 AM #17
sakin naman yung experience ko di naman ako namatayan nung nasira starter ko yun nga lang di ko ma start yung engine hanggat mainit pa kaya pinalalamig ko muna.nung nag palit ako ng starter naging ok na and hopefully hanggang ngaun ok pa din yung auto ko.civic lx 92 ph15 carb.
April 19th, 2011 08:16 AM #18
April 19th, 2011 08:20 AM #19
- Jul 2010
- 166
April 21st, 2011 12:30 AM #20paano naman po kung delayed response? kunwari po biglang tapak sa gas tapos mga 2-3seconds po bago magresponse ang makina, ano po kaya problen sa ganon?
It's about 1 cm longer than the 3SM and about 4 cm longer than the DIN74. And it's also in the 10k...
