Results 1 to 10 of 23
Registered User
- Sep 2011
- 1,313
May 28th, 2013 10:55 PM #1ano ano po ba ang pwede i mod sa 2.5 d4d para lumakas ang performance ,yung mod na walang kakalikutin sa makina or sa differential , Yung mod na install install lang ,
ito po list ko .
- EGR blanking plates
- K&N air filter
- race chip
- intercooler ? ( medyu alangan baka maraming gagalawin sa makina, ma letse pa )
- Fuel Combustion Enhancer ? ( testing ko sa advie namin dati parang bumilis )
any mods po na ma suggest niyu ? and kung ano mga advisalbe at hindi na mga mod :sweat:
i dont need speed ang gusto ko kahit lumakas lang ang arangkada at power ng performance, peru pwede na rin kahit madagdagan ang top speed kahit 10-15kph lang ;)
May 28th, 2013 11:14 PM #2
Kung simple mod lang, chip ang suggestion ko. Kasi plug and play lang then tuning nalang.
BANNED BANNED BANNED
- Feb 2013
- 487
May 28th, 2013 11:18 PM #3Di pa ako nakapagdrive ng D4D, and lalo na ng Innova na D4D kaya di ko macompare yung arangkada from zero kung alin talaga mas mabilis kung ang D4D or VVTI.
Pero dahil diesel ang D4D I bet mas mabilis aahon from stop ang D4D. Kung power (horsepower) pag uusapan, wala na yan ilalakas pa, mag VVTI ka kahit tops speed wala binatbat D4D.
Wag ka mag K&N, dudumi intake mo.
- Sep 2011
- 626
May 28th, 2013 11:23 PM #4How about A Unichip? Alam ko mas mataas gains niya compared to other Chips e.
An FMIC upgrade would also be good sir
May 28th, 2013 11:26 PM #5
Egr blank plates will give your faster spooling of the turbo and quicker response. Both ends should be blank.
Hurricane filter is the most performance filter in the market but this should be conjunction with alcohol injection
Alcohol injection will also give you torque, Hp & will keep your engine always at optimum performance.
Is your 2kd-ftv VNt? If not, after installing a water/alcohol injection, install a boost controller and bump your boost 1-3psi up
200ml per 40L of 2T oil & diesel to keep your diesel injection/pump happy
Delete your catalytic converter if you have installed a water injection
3" full exhaust from turbo-muffler will also inprove performance
Fuel management (chips)
Hth
May 28th, 2013 11:28 PM #6
Also, the water injection will keep your full intake almost carbon free.. That is why hurricane filter is conjunction with alcohol injection
Registered User
- Sep 2011
- 1,313
May 28th, 2013 11:54 PM #7^ hindi sir non vnt, 102 hp lang, ano po yung alcohol injection ? :sweat: , may nag suggest din sa akin ng speed booster,
bakit sir po ba ok ang filtration ng k&n ,? :sweat:
kahit arangkada wala siguro binatbat ang d4d, kasi gas ang vvt-i walang hangganganan, at madaling sunugin kumpara sa diesel , madalas kasi ako ahunan lalo sa baguio kaya need ko ang power lalo na kapag punuan , kaya hindi ko talaga kaylangan ang madagdagan ang top speed ;)
ito'ng chip lang talaga ang alam ko na mod effective sa diesel engine, the rest suggest and research ko lang
May 29th, 2013 08:39 AM #8
If i had an Innova for my personal use:
- Drop-in filter
- Alcohol Injection
- Uni Chip (+ dyno tuning)
???+> Boost controller and gauge (Any one tried this on a D4d already?)
Re. K&N, we've been using this for ages in our cars (since the 1990s) and with regular cleaning and re-oiling, we never had any problems related to dirty intake plenums. If ever, it's just the same as any car that hits high mileage which will need TB cleaning after several years and well over a 100K of service.
I would not really go over on the power of the Innova though as at the end of the day, it is still an MPV and not a sport sedan. At most, based on what i feel whenever i use our family Innova out of town, i always wanted better low-end to mid range power from the a/t version for climbing and passing during highway runs with a moderate to heavy load.
May 29th, 2013 02:25 PM #9
May 30th, 2013 10:46 AM #10
I've driven both. VVTi & D4d Innova.
the 2.0 VVTi is really really slow. you really have to step on the gas to get it going. That means bad FC too.
The 2KD-FTV gets you to decent speeds faster than the VVTi without really pushing it. Yun nga lang wala masyadong top speed.
I am currently observing the 2SM battery installed on my MU-X, Yuasa brand. Kaka 1 yr lang nito...
