Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jul 2010
    ano po ba dapat talaga, city driving, on o off ang overdrive? kasi by default naka-ON sya, tipid ba sa gas yun o mas malakas sa gas yun pag overdrive on sa city driving? norbal ba sa altis 1.6 a/t ang 7.5kilometers lang per liter city driving? overdrive always on po yan.
    Aug 2004
    Depends on the route. But in traffic, yes.
    No need to turn OD off unless you want to overtake. You can fiddle with the ECT switch (if your car is a later generation Corolla with the ECT) to see if it gives you better economy, but in ECON mode, it's kinda sluggish.
    Jul 2010
    yup i have ECT, pero mag 5years na car ko til now really dont understand whats that for... hehehe
    Aug 2005
    Keep OD on.
    Pag mabilis na tapos gusto mong mag down shift from 4th to 3rd, you can turn OD off.
    If you need acceleration. Turn On ECT. else keep it off.
    Pag naka ON ang ECT, at a higher RPM mag shift up ang transmission. higher revs = more power but more fuel used.
    Jul 2010
    so ok yung 7.5kilometers per liter ko sa city?
    ok na po yung 7.5km/l sa altis matic sir
    Jul 2010
    Generally speaking, overdrive (OD) is the highest gear in the transmission. Overdrive allows the engine to operate at a lower rpm for a given road speed. This allows the vehicle to achieve better fuel efficiency, and often quieter operation on the highway. When it is switched on, an automatic transmission can shift into overdrive mode after a certain speed is reached (usually 70+ km/h depending on the load). When it is off, the automatic transmission shifting is limited to the lower gears. For an automatic transmission, it is almost always best to select overdrive and allow the transmission to control engagement of the overdrive. (It may be necessary to switch it off if the vehicle is being operated in a mountainous area or when towing a trailer.) With a manual transmission, overdrive should usually be selected when the average speed is above 70 km/h.
    From pareng Wiki-yan explanation nya....
    On cars without this OD switch like mine (D, D3, D2), the D it our overdrive. D3 and D2 in effect is the overdrive in off state.
    Aug 2009
    select OD On manila road, OD Off in kennon road, Baguio.
    or you can use OD Off as an engine brake......
    Aug 2004
    Quote Originally Posted by 1stgear View Post
    Depends on what part of Kennon. On the steeper inclines, 1st or 2nd is a good precaution so you don't cook your brakes. I was rear-ended there once by a Civic with a newbie driver. He didn't preserve his brakes on the way down, and when we came to a stop at a landslide, he ran into me from over 100 feet away.
altis Overdrive ON or OFF?
