Results 441 to 450 of 926
- Sep 2007
- 267
June 9th, 2018 02:55 PM #441Depends on the traffic. Which is why I agree with the earlier post requesting for average speed data. I wonder though if the Rush has it in its MID.
8km/l for 15kph average speed is relatively good, but 8km/l on a faster 20kph average is low. Both are city driving. That's why it's so hard to say a car is fuel efficient without a corresponding average speed.
But yes, the poster (levisph) represents only one data point and he could very well be an experienced hyper miler to be able to pull off that kind of driving economy.We need more data points.
June 9th, 2018 03:12 PM #442
My Civic's average speed does not reset per trip, I have to reset it manually every full tank. I always fill up before going out on the highway to isolate city driving from highway driving. I don't find it a hassle at all.
Rush hour when I go from my house in Pasig to BGC is 6 km/L. Rush hour when I go from my fiance's condo from QC to BGC is 7.5 km/L. I consider both to be rush hour driving but QC to BGC has a higher average speed.
That's why again, average speed is a very important number that helps put FC figures into better perspective. Otherwise it's all speculation and assumption.
I understand not everyone is as meticulous in tracking FC, which is why I take everything on the internet with a grain of salt until I see their methodology.
- Sep 2007
- 267
June 9th, 2018 03:38 PM #443My Civic's average speed does not reset per trip, I have to reset it manually every full tank. I always fill up before going out on the highway to isolate city driving from highway driving. I don't find it a hassle at all.
- Jun 2018
- 12
June 9th, 2018 09:13 PM #444Apologies I forgot to include average rush hour speed. This is mostly EDSA - Taft - Gil Puyat - Makati CBD route:
- Morning: 30 to 50 kph depending on the time/traffic
- Evening: 20 to 40 kph normally. Edsa crawl in the evening is even slower at times - 10 to 15 kph
I am still in the process of monitoring this figure. Will post another update after a month.
Hope this helps.
Addendum: I made sure to track my ODO reading whenever I filled up the gas tank so I can compute number of kms traveled vs number of liters consumed. Specific to the Bolinao trip, I deliberately topped up after specic sections/legs to ensure isolation of the FC readings.
- May 2016
- 546
June 9th, 2018 09:32 PM #445
June 10th, 2018 12:07 PM #446
That's not what we mean by average speed. Most decent new cars have average speed meters in their MID. It's basically total distance travelled divided by total time your car was running, so it includes all the stops you have in gridlock traffic, all the instances you slow down in an intersection, and so on. You'll be surprised that the average speed between heavy traffic and light traffic in the city is just less than 10 kph.
From experience, purely heavy EDSA traffic is around 12-15 kph. Moderate traffic is around 16-20 kph. Anything above 20 kph average speed is already light traffic.
On the highway, if you drive exclusively on the highways, average speed is usually around 70-80 kph. This is if you cruise around 100-110 kph when the road is open. Again, the number is lower because it considers the time you're moving at 0 kph at the tollgate, or the times that you have to slow down because of a truck.
- Jun 2018
- 12
June 12th, 2018 09:38 AM #447Unfortunately no Average Speed as part of the multi info display. Only ODO, Trip A, Trip B, Km/l, Average Km/l is available, plus the clock of course
My Average Km/l so far since I acquired the unit is approximately 10.9 based on the multi info display. This is close when you average my FC trips so far (15 km/l hi-way + 12 km/l mixed + 8 km/l daily commute, divided by 3 is 11.6)
Most likely the Multi Info Display Computer is more accurate. This is related to the input provided by jut703 regarding Average Speed computation (I.e. Slow speed during stops/tolls combined with average cruising speed)
- Sep 2007
- 267
June 12th, 2018 10:27 AM #448The mileage displayed by the MID is only an approximation. Most of the time it's off by around 0.2 to 0.5 km/l. But depending on car make and/or driving conditions, it can be off by as much as 1 km/l sometimes.
Since your MID does not show average speed, the most accurate way to get your average FC is still the full tank method wherein you divide total distance travelled by the amount of fuel put in. We could start with that figure and then try to validate backwards to determine the MID's accuracy for your highway and city FC figures.
Thank you for the updates.
By the way, are you an eco-conscious driver who likes to see the eco indicator turn green all the time? Or are you the devil may care upak type?
June 12th, 2018 10:58 AM #449
- Sep 2007
- 267
June 12th, 2018 01:56 PM #450That's the assumption. But have you ever had your actual computed mileage using the full tank method align perfectly with your MID's readings? My limited experience across several car brands over the last decade is that the FC indicated by the MID is almost always optimistic by varying degrees. And that is why we'd like the poster to achieve a base line. Of course it would be ideal if the car is gassed up in the same station using the same type fuel and using the automatic click method.
But who knows, baka naman super accurate yung reading ng Rush since it is very new. But I'm not counting on it until we have proof and more data.
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
