Results 591 to 600 of 1371
- May 2016
- 45
August 29th, 2016 08:55 PM #591gudpm sino po naka Freedom White dito?
paano magtanggal ng light scratches due to car wash boys na bara-bara magpunas?
August 30th, 2016 01:34 PM #592
Changing car washes is the first step.
Waxing regularly comes next (it will also help keep your white exterior... white)
Scratches may be caused by:
- Wrong methods used: They don't rinse the vehicle thoroughly before applying and spreading the soap (sakit ito ng maraming car wash-car washan na nagmamadali lagi);
- Wrong materials used (ideally, a microfibre towel or wash mitt is used);
The scratches are caused usually by those two as first, scratches come not from the towel or wash mitt material in most cases but the dirt on the car that is not dislodged properly and rubs against the surface when the washboy runs through the car haphazardly. Using a regular towel, sponge, or trapo that does not trap dirt adds to this as well; A microfibre towel or microfibre wash mitt traps dirt to further reduce the surface contact dirt elements).
- May 2016
- 45
August 30th, 2016 07:44 PM #593
very well said sir. kapag ako naglilinis, nag 2 buckets method ako.
usually napapansin ko na lang din kasi yung bagong scratches kapag ako na ulit maglilinis huhu
by tomorrow magpa insurance ako, as per casa estimate need to change my tailgate at hilux emblem
binangga ng lasing na tricycle at tumakbo. luckily na trace namin operator, got an installment settlement.
ok na rin yun kesa wala
August 31st, 2016 09:26 AM #594
- May 2016
- 45
September 1st, 2016 06:34 PM #595meron akong napapansin under the steering wheel area, kapag nasa 4th -5th gear ako
at mag accelerate, may "tik-tik" sound, like flickering electrical etc...
pinadiagnose ko kasama ng 5000k checkup, ang advise nila Normal lang daw yun.
usually yung naririnig ko daw feedback ng valve etc..
concern ko lang naman baka mamaya magkaproblema regarding faulty wiring,
knowing wala naman akong ibang pinainstall, all stock.
sa inyo, meron po ba kayong na experience na ganitong case...
- Jul 2009
- 2,618
September 1st, 2016 06:47 PM #596
- May 2016
- 45
September 1st, 2016 08:00 PM #597
- Aug 2016
- 194
September 1st, 2016 11:32 PM #598Matic ba yan sir o manual?
- Jul 2009
- 2,618
September 1st, 2016 11:43 PM #599
- May 2016
- 45
September 2nd, 2016 11:02 AM #600
It's about 1 cm longer than the 3SM and about 4 cm longer than the DIN74. And it's also in the 10k...
