Results 421 to 430 of 1371
April 21st, 2016 12:56 PM #421
The Grandia gearing will not allow it to climb a steep grade on second gear. Heck, even the first gear is a little too tall if you're doing it from standstill. The engine has no problem and it's more of a gearing issue.
In that situation:
If you can back up and start from the bottom, better.
If you cannot, pull up the hand brake to immobilize the car, press the gas pedal to increase your rpm while releasing the clutch steadily and when you feel the engine bite at the optiumum rpm range release the handbrake steadily.
April 22nd, 2016 01:16 PM #422
April 22nd, 2016 02:08 PM #423
Sir Vinj ask ko lang if youre shoes on the new hilux is 20s or 22s? Thanks
- May 2016
- 45
May 15th, 2016 09:13 PM #424up ko lang po ang thread kasi plan ko kumuha ng 4x2 E MT
ano pong mga freebies na pwede kong ipa add sa agent, like bedliner, bed cover rain visor etc.
thanks.
btw, magkano po additional pag magpa alloy sa stock rims ng E variant
- Aug 2009
- 7
May 16th, 2016 01:52 AM #425Mga boss, what can you recommend for suspension upgrades? Need ko sana comfort sa daily drive and could bare occasional 300 KG Payload. and kaya po ba boss gayahin ng mga aftermarket shocks ang ride ng 2016 Fortuner? Salamat po
May 17th, 2016 09:55 AM #426
Look for someone selling the OEM alloy 17 rims and larger tires. Meron sa olx. That's the best fit.
I usually check Old Man Emu shocks or Bilstein but these will cost you roughly 40-50K for a set. Atoy sells the Bilsteins to include a 2-inch lift when i checked their FB page.
- May 2016
- 45
May 17th, 2016 10:54 AM #427
May 18th, 2016 09:59 AM #428
- May 2016
- 45
May 24th, 2016 07:00 PM #429
May 26th, 2016 12:18 PM #430
Ilang taon at km run na yang casa stock battery na motolite mo ?
