Results 991 to 1,000 of 8993
September 15th, 2013 11:25 PM #991
Hello mga bossing. Nung thursday ko lang nakuha bago vios ko na 1.3e at. Parang medyo malakas gas consumption nya. Ganun po ba talaga or magiging matipid din sya later on? Thanks
September 16th, 2013 02:20 AM #992
- Sep 2013
- 33
September 16th, 2013 09:47 AM #993Had our dark brown 1.5G A/T for a week now. Here are my impressions:
After picking up the unit from the CASA, I noticed that it had clocked 9km in its odometer and that the fuel indicator is already at the empty region with its light indicator already on. My Agent told me that from the plant, all Vios comes with 10 liters of fuel only. This was a concern because when I toggled the trip computer settings to show the average fuel consumption, it was showing a dismal 3km/l. Good thing that there was a gas station near the dealership, but it necessitated me to navigate through a U-Turn and wade thru bumper-to-bumper traffic. To date, after a week of usage and 128km of accumulated distance travelled, it is now showing 6.9km/l. I expect it to improve even more in the coming weeks/months during the break-in period.
I had carefully studied my purchase of this car. My main consideration was budget. next would be the combination of: economy, reliability, longetivity, comfort, looks, as well as adequate power. I was not disappointed with what I got. Power is more than sufficient to climb up Antipolo without difficulty while baby-ing the throttle. The brakes are something I need to get accustomed to--a little prod is enough to lunge you to the dashboard if stepped on suddenly. Comfort-wise, its good. There is some noise on the ride over bumpy surfaces that intrudes into the cabin, but this is maybe due to incorrect tire pressure which I still haven't checked yet. The only time that engine noise would intrude into the cabin is when the tachometer enters the 3000RPM zone during overtaking, otherwise it is placid most of the time. Spring and damping over speed humps is good as well, though haven't had the chance to see with full passengers onboard. NVH levels is top notch for me. The cabin is really silent with the windows rolled up. Radio/Stereo sound quality is good considering it is stock unit. But for the discriminating folks, it wouldn't do. I like the USB/IPOD capability, as well as the remote controls on the steering wheel.
My nitpickings would be:
1. Non-telescoping steering wheel-I probably belong to a small percentile of people with long legs compared to their arms. This isn't a worry since the steering assistance varies with speed.
2. Cheap, flimsy A/C controls. Turning the fan speed knob on felt like it wouldn't last a year. The same can be said for the other knobs in the HVAC.
3. Non-foldable rear seats. This would have made it more practical.
4. (Rather) Weak headlights. With a stock HIR2 bulb/projector lamp combination, I was expecting more, or probably my expectations were just too high.
5. A/T is sometimes undecided during part-throttle inputs. I'm not sure it it has an adaptive logic to suit its driver, but there are times it is caught between 1st and 2nd gear. I noticed this too during my back-to-back test drive of 1.3AT and 1.5AT. I felt that 1.3AT was more smoother although it has a lesser urge when flooring the throttle.
I am quite happy to have gone over the user manual to check for the PMS schedule. Its service requirement is far and few than what I had in mind. For everyone's benefit, here they are (1.5AT):
Head Light: HIR2/9012 bulb
Fog Light: H16/5202 bulb
Other Lights: Wedge/Single End bulbs
Oil: 3.7L (with filter) 5W-30/10W-30 API SL/SN/SM or ILSAC
Coolant: 4.1L Ethylene Glycol non-silicate, non-amine, non-nitrite, non-borate
Spark Plug: Denso K16R-U / NGK BKR5EYA
AT Fluid: 6.4L Toyota Genuine ATF WS
Brake Fluid: DOT3
Tires: 185/60R15 84H-33psi/30psi / 195/50R16 84V-32psi/29psi
Engine Oil: 10K/12mos. replace
Oil Filger: 10K/12mos. replace
A/C Filter: 30K/18mos replace
Drive Belts: 20K/24mos. (inspect)
Cooling: 40K/24mos. replace
Spark Plugs: 10K/12mos. (inspect) 40K/48mos. replace interval
Brake Fluid: 10K/12mos. (inspect) 40K/24mos. replace interval
Air Filter: 20K/24mos. (inspect) 40K/48mos. replace interval
Fuel Filter: 80K/96mos. replace
AT Fluid: 40K/24mos. inspect 80K/48mos. replace interval
Valve Clearance: 80K/96mos. (inspect)
Hope this helps to fellow forum readers.
- Jan 2013
- 149
September 16th, 2013 11:42 AM #994
- Oct 2008
- 525
September 16th, 2013 11:49 AM #995for me puede na sya but it is somehow lacking the high part of the music. puede kaya lagyan ng tweeters ito? for the bass part, I usually set it at 1 or 2 out of 5. adequate na for me but of course the sound wouldn't be as low vs those with added amps and subs.
AM reception seems to be coupled with some humming sounds regardless of station. Anyone experienced this? With regards to the USB port, I have experienced freezing music during playback. What I did was replace the USB stick with a similar 7GB TDK and all is well.
- Jan 2013
- 149
September 16th, 2013 11:51 AM #996
- Jan 2013
- 149
September 16th, 2013 11:56 AM #997
September 16th, 2013 05:37 PM #998
- Sep 2011
- 262
September 16th, 2013 09:51 PM #999
- Jul 2008
- 114
September 17th, 2013 10:23 PM #1000Quite intermittent lately, the door lock sign on the dashboard blinks. Very split second lang. Lahat naman ng door e naka-lock. Has anyone experienced this?
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
