Results 1 to 10 of 61
- Sep 2007
- 49
April 22nd, 2008 01:53 AM #1I was told that this engine is great, power in less fuel consumption. Please post a reply about your experience with the engine and please clarify if this engine really do have vvti. thanks
April 22nd, 2008 04:11 AM #2
My neighbor has one in his small body corolla. He has a jasma 4-1 headers connected to it and all stock internals. Here are some points that I've noticed.
1. At stock, it is fast but nevertheless it's not as good as a B16. It has torque thou not like the b16.
2. Yes it does have Vvti. I know how vtec works but I don't know how Vvti works. I assume it's the same thing.
3. It get's hot easily.
4. Throttle position is a little bit off if it's on a FF. It would be better if it's on RWD.
Rating 8/10
April 22nd, 2008 05:06 AM #3
- Apr 2008
- 2
April 22nd, 2008 05:20 AM #4We use 20Valves here in the states, It works great with the stock parts as far as putting it on a Corolla either you need to punch a hole on the firewall or get the mod parts to route the Dizzy to the front. since the motor was made for a Front Wheel Set-up. You can check a really good site: www.club4ag.com for more info on this motor and im sure you'll find whatever you want to know about this motor and other mods.
Hope this helps,
I need a contact for old school parts, Side Drafts for an 18RG Set-Up and 4AGE. Supercharger for a 4AGE.
Thanks all
Mike Ibarra
April 22nd, 2008 08:40 AM #5
April 22nd, 2008 09:00 AM #6
hey bro, well the 4AGE 20Valve "black top" is a pretty stout engine (aluminum head / cast-iron block) so it can take alot of beating. also, the 20 valve is a very good "high-revving" engine and it has a good amount of Horsepower and Torque, considering its a 1.6L engine. plus the 20 valve is easy to maintain and there are still some aftermarket support for it.
anywayz, here some other things that I like about the 4AGE 20 Valve engine (wether if its a Silver or Black top):
-inexpensive.
-engine is strong and easy to maintain.
-non-interference engine.
-Aluminum Head & Cast Iron Block design (which is stout and can handle forced-induction applications.. with internal mods of course.)
-has ITB's (Independent Throttle Bodies) and is simple to tune.
-high-rev engine w/ low-mid end torque (these engines like to be driven hard)
-good availability of OEM and Aftermarket parts.
-can be put on literally any generation of Toyota Corolla's (TE27, AE86, AE92, AE101, AE111).. you can even put this engine on a KP61 Starlet!
aite, peace.
April 22nd, 2008 09:34 AM #7
Ayun. VVT pala not VVTi. Thanks for the correction. Yup the engine likes to be driven hard.
April 23rd, 2008 04:06 AM #9
April 23rd, 2008 10:40 AM #10
ive heard na its a good engine and easy to maintain. im thinking of putting one in my AE111. Mga bros, san makakakita and how much ang 4AGE? anong difference ng black and silver top?
peace!
Otoh, the 2nd gen mu-x slightly looks like a mazda up front and some interior bits as well but oto...
2022 Mazda BT-50 (3rd Gen)
