Page 15 of 27 FirstFirst ... 511121314151617181925 ... LastLast
Results 141 to 150 of 266
    #141
    Quote Originally Posted by 17Sphynx17 View Post
    I am wondering though if the HEV pricing is just an introductory pricing that will increase by the 4Q or "2nd batch" and later deliveries.
    But at the current SRP, it looks like a winner already.
    Introductory price. They will most likely increase it in a month or two.
    Toyota is always keen to have price increases at least once a year for every model. for some model twice or thrice. some with corresponding additional equipment or color variation while other increase are just that.
    #142
    Edit: The new Innova, per the reviews shown, is for 6 adults right (if with the Captain Seats)? and 7 adults if they retained the bench seating in the second row? So at 75kgs per person results in 525kgs, excl luggage.
    Zenix is a 7-seater MPV, it has a 2+2+3 seating arrangement. The third row is for three passengers (that explains the central headrest). The two Zenix variants launched here come with 2nd row captain seats.
    #143
    Will people flock to the 2.0 liter V version or will people still prefer the Innova diesel? Abangan...
    the 2 liter gasoline hybrid will be like a diesel sa tipid
    #145
    costumers will probably buy it primarily for the coding-proofness and everything else is secondary.
    #146
    Quote Originally Posted by AG4 View Post
    There's a display unit at festival mall. May lalagyan ng drinks sa Center ng 2nd row kaya 2 lang pede sakay. Yung pinto sa likod eh automatic open and close, it's beeping while it's opening or closing.
    Yung seat sa 2nd row parang recliner seat. Mahihiga mo yung sandalan at may salo sa binti na matataas mo.
    yes the no-coding incentive works
    #148
    For the moment, I haven't been able to find if the Zenix has any advertised "payload" capacity. The ladder frame Innova theoretically could be loaded with 1000kgs (1 metric ton) as it rides on the same IMV frame as the Hilux and Fortuner.
    Where are you getting 1 ton payload from? Crew cab Hilux max payload is only 470kg. The ladder-frame Innova is actually slightly better at around 600kg.
    If you're planning to carry 1 ton you need the Hi-Ace which has a high GVM.
    #149
    222 Toyota Hilux GR Sport Brings Rally-Inspired Goodies to Europe's Truck Segment - autoevolution
    At the second to the last paragraph
    "Power comes from the same 2.8-liter engine that was introduced in the Hilux in 2020. Working in concert with a six-speed automatic transmission, it produces 204 ps (201 hp / 150 kW) and 500 Nm (369 lb-ft) of torque, giving it a payload of 1 ton (2,205 lbs), and braked towing capacity of up to 3.5 tons (7,716 lbs)."
    The Nissan Navara, Ford Ranger are also advertised to carry 1ton payload on its bed as far as I am aware.
    for a 2.4Diesel Innova, Kerb Weight is 1800~1855kgs, GVW is 2400~2480kgs (depending on trim) based on the site since Toyota PH doesn't provide it in their brochures.
    Toyota Innova Crysta Specifications |ET Auto
    Weight difference of about 600-650kgs.
    That's why I am just on the impression that the ladder frame is rated for 1 ton payload as it shares the IMV platform for Hilux, Fortuner and Innova previously. Of course that doesn't account for the weight of the third row added onto the frame.
    EDIT: I came across a website that does mention Hilux having a max payload of only 470kgs but other sites mention around 900~1000kgs payload capacity.
    In addition, found an old review from CG for 2014 2.5 Dsl Innova
    https://www.car guide.ph/2014/07/review-2014-toyota-innova-25-v.html
    Curb Weight used to only be around 1670kgs, or it was about 200kgs lighter before using the same platform. No idea about the GVW for the same model though. Couldn't find it in the same article.
    Jan 2011
    #150
    Very little info has been published about the hybrid drive train of the Zenix. From the wiki page the Zenix apparently has NiMH batteries instead of Lithium. A bit disappointing but it is fit for the purpose. The choice of NiMH most likely driven by the need to keep the cost of the vehicle within a target range.
2023 Toyota Innova (3rd Gen)
