Results 1 to 10 of 46
- Feb 2014
- 2,694
November 12th, 2021 12:14 PM #2
technically it has (same as the Rush) kaso welded to the body
Toyota Avanza Facts: Updates you need to know | Autodeal
Featuring a ladder frame that’s welded together with the body and floor pan, the Avanza technically rides on a unibody chassis that offers good ground clearance and versatility.
- Feb 2014
- 2,694
November 12th, 2021 12:29 PM #3
November 12th, 2021 12:59 PM #4
- Dec 2019
- 2,073
November 12th, 2021 01:23 PM #5Avanza is unibody since introduction. The drivetrain layout only has changed from longitudinal engine RWD to a transverse engine FWD.
Here's the Daihatsu sibling, the Xenia. If Daihatsu is making a comeback to PH they should bring this too.
2022 Daihatsu Xenia is Avanza's more affordable twin -AUTOINDUSTRIYA
- Feb 2014
- 2,694
November 12th, 2021 01:32 PM #6
here's the avanza's u-shaped frame supports welded to the body to provide add'l strength where it's needed. the engine and suspension are bolted to them.
this is typical of monocoque cars. a honda city is built pretty much the same.
to say that a car has a ladder frame... it simply has to have one. i.e. a robust frame independent of the body
- Jan 2008
- 4,726
November 12th, 2021 02:40 PM #7
November 12th, 2021 03:11 PM #8
ok... there's body on frame -> ladder frame
This site differentiated Unibody and Monocoque, Unibody vs Monocoque - What's the difference?
And if we follow the site, the 1st and 2nd Gen Avanza are "unibody"
An automobile construction technique in which the body is integrated into a single unit with the chassis rather than having a separate body-on-frame.
The 12-month warranty on the factory battery ended a few days ago. SOH is still good at over 90%,...
