Page 16 of 33 FirstFirst ... 612131415161718192026 ... LastLast
Results 151 to 160 of 324
    Mar 2017
    #151
    Quote Originally Posted by kitoymonster View Post
    Inclined yung daan dun sa harap ng bahay kaya mahirap ipark kung d ko ma point down ang passenger side mirror.
    Automatic econ mode yata ang car kasi wala akong makitang area to turn it off except if you go over certain speed
    My 2nd gen Vios E didn't have power mirrors either.
    The "econ" light is just an indicator that your are driving "economically." But it's not a mode.
    The horn says miip-miip instead of beep-beep. Napatawa yung nakasabay ko na adventure driver sa ka cute ng horn sound.
    Unlike the old Corolla XE's, all Vios's have only single horns, kaya meep-meep and tunog. Even my 11th gen Altis was the same. That's why I had the casa upgrade them to Bosch Fanfare EC6 before they were released.
    Feb 2019
    #152
    Quote Originally Posted by makinao View Post
    Thanks for the tip, ganda din pala purpose ni eco light. Na remember mo pa po ba yung price ng bosch horn?
    Mar 2017
    #153
    Cant remember exactly, but it was about double that Banawe. Pero ayaw kong ilabas ang kotse ng pipitsugin ang busina, at ayaw kong ma-void ang warranty. But a 1k+ pesos was a small price to pay considering I just paid more than half a million on a car.
    Feb 2019
    #154
    Guys just another noob question: How do you unlock/lock the car properly? I’m so ashamed in asking this pero may instances na i-lock ko ang sasakyan pero yung driver door unlocked parin. So I ended up doing the lock->close the door while pulling the door handle out.
    Jan 2019
    #155
    You might be using the door-lock knob.
    Try using the door-lock switch (yung katabi ng power window lock switch), press the "lock" side on the open front door before closing. Be careful not to leave the keys inside your car.
    #156
    it's not shameful naman.
    many folks do it all the time... lalona yung walang power locks.
    also, you might try using your key to manually lock the door.
    personally, i do not see the problem.
    Mar 2017
    #157
    ^ From inside, or outside of the car?
    Feb 2019
    #158
    Thanks. It’s just so basic and nakakahiya medjo na pa-ulit2 akong ng lock tapos always unlock..haha
    From the outside. I don’t know whats the exact steps kasi hindi naman all the time nangyayari pero usually pagpark ko, unlock ko ang door using the unlock button above the power window, then paglabas, close ko ang pinto tapos lock ko gamit yung susi. Kahit na may lock mechanical sound, unlock parin. Yung solution ko nalang is buksan ang pinto, lock ko gamit yung key, then cose while pulling the door handle - the classic lock way.
    Mar 2017
    #159
    In my experience with Toyota cars, that's weird. The sequence for manual locking should be:
    1. unlock the door to get out of the car
    2. open the door and get out of the car
    3. shut the door
    4. lock the door manually with the key.
    5. just to be sure, pull the door handle. if the door doesn't open, then it is locked.
    Simple. If this doesn't work, its either the door is not completely shut, or there is something wrong with the lock. Complain about it when you take it in for the 1k PMS.
    Jan 2019
    #160
    Without using the key, na-try mo na rin ba gamitin yung "lock" button (beside power window lock) habang nasa labas ka na, bago mo isara yung pinto?
2019 Toyota Vios 1.3 XE
