Results 111 to 120 of 324
February 14th, 2019 02:56 PM #111
- Jan 2019
- 39
February 14th, 2019 04:05 PM #112I'm saying depende yan, bro. First, know the capabilities of your car. If in doubt, check natin ang owner's manual:
* Downshifting - On a steep downgrade, downshifting helps maintain safe speed and prolongs brake life.
* Do not use engine braking on slippery road surfaces or at high speeds.
* Descending steep grades - When descending a steep grade, shift to lower gears, depending on load weight and grade steepness. Descend slowly, using the brakes only occasionally to prevent them from overheating.
All the above points are in the Manual Shift Mode (Shiftmatic) section.
Yung sinasabing brake assist, pang emergency situation lang yan.
"During emergency braking situations when it is necessary to depress the brake pedal with greater force, the break assist system provides braking assistance, thus enhancing breaking performance.
When the brake pedal is depressed hard or depressed more quickly, the brakes apply more firmly."
- Feb 2019
- 32
February 14th, 2019 04:27 PM #113Maraming salamat at may mga iba ibang braking techniques akong nalaman. Nung first time kong umakyat ng mountain road kasi ng brake lang ako either fully or slightly but never ko tinanggal paa ko pag downhill. Pagdating sa baba, amoy sunog yung driver side wheel area. So yun brake nalang for 3-5 seconds, release for a few seconds then brake ulit. So set kung tama yung pgka intindi ko, brake hanggang bumaba ang rpm, set gear to M1, then brake? Mg auto gear ba ang car to M2, M3 kung hahayaan mo lang?
- Jan 2019
- 39
February 14th, 2019 04:44 PM #114Bro di ko kasi masabi yung exact gear, depende yan. Ginagamit ang engine break para kontrolado mo bilis (speed kills daw), so M1 or M3 depende sa pakiramdam mo sa makina. Basta wag siguro aabot nang 3000-ish rpm (maingay ang CVT). Mag auto upshift lang sya kapag nag red line (o may preset settings ang ECU) para maprotektahan yung makina. Again, "steep downgrade" pinag-uusapan dito ha, lalo na yung maraming curves.
Pwede naman talaga D lang gamitin mo, tapos brake lang, pero kung may skills ka na para mag engine brake why not. Mahirap mawalan ng preno. Mas mahal ang transmission kesa brake pads, pero mas mahal ang buhay kesa transmission
As for me, for regular stop and go traffic: brakes lang. For very steep downgrades: downshift with intermittent braking. Again, ang objective dito: safe speed and control. Be extra wary din sa engine braking when slowing down tapos may kasunod ka sa likod, hindi kasi umiilaw ang brake/tail lights mo. That's why use brakes as necessary.
Iba ibang opinion/diskarte naman yan, and I respect that. Pero yun nga, check lagi owner's manual
- Jun 2005
- 3,774
February 14th, 2019 05:01 PM #115All the more reason to test drive.
With zero expectation, you will be at the mercy of agents trying to make money from you. Test drive a the vios, compare this with other cars within the price range, then decide which is best for you.... Unless you feel like blindly throwing 700k pesos for a car.
Sent from my MI MAX 2 using Tapatalk
BANNED BANNED BANNED
- Sep 2015
- 13,917
February 14th, 2019 05:30 PM #116magdagdag na lang kayo konti para honda city na. Eh hulugan nyo din naman babayaran.
Its time to move on from mamon to cheescake, from pandesal to croissant.
February 14th, 2019 05:43 PM #117
- Jan 2019
- 39
February 14th, 2019 07:08 PM #118
- Feb 2019
- 32
February 14th, 2019 07:41 PM #119
February 14th, 2019 07:53 PM #120
Laki pala problem ng BYD sa stocks ng mga collision parts (bumpers, lights, etc.). I have 3 friends...
BYD Sealion 6 DM-i
