Page 18 of 22 FirstFirst ... 8141516171819202122 LastLast
Results 171 to 180 of 212
    #171
    I backread and found that 2017 wigo has "faulty wiring problem" should this be a cause of concern? If I bought a 2017 or earlier wigo 2nd hand can this be easily fix outside casa?
    talagah?
    well,
    i googled and it seems an easy fix naman.
    i am sure toyota will rectify the issue, free, even if it is already the second or third owner bringing it in. best they do it for you, to maintain warranty.
    my 2014 wigo did not have such recall issues.
    what i do know, is that the first 2014 model's silver paint on the plastics inside, tended to wear thin easily over time.
    Feb 2019
    #172
    With the price of a 2017/2018 wigo, you woul be able to get an early 10th gen, fairly reliable Altis. It is older, but not impractical either, especially if its just a second car. My civic is 10 years old, but it has no problems yet. I'm a sure a similarly aged Altis wouldn't be more problematic, even as compared to the wigo
    So a 10th gen altis is around what year model? I will look into it.
    #173
    ah ha!
    a convert!
    Feb 2018
    #174
    iirc it starts with the 2008 model
    Feb 2019
    #175
    ah ha!
    a convert!
    Hehe not really but im leaning towards wigo as it will be a much newer model. Btw, haven't look at mirage is it just similar to wigo? Im biased with toyota.
    #176
    "buying used" is not new to me.
    knowing auto-mechanics (i.e., "i bought and repaired an ex-taxi!") is an advantage.
    being financially capable and amendable, also helps (for the expected post-purchase repair).
    a tsikoteer here says, for the money, mirage is ok.
    others, however, say mirage has design issues that keep the owner on his toes.
    me? i'm a toyota fan.
    so, what problem did my 5.5 year-old wigo give me?
    nothing dramatic.
    but the "up" function of the driver-side side mirror is busted. it sounds like may nasira or kumalas sa loob. fortunately, it is easy to reach out and manually move the mirror, so i haven't been inspired to fix it, yet.
    also, when the battery dies, replace it. for some reason, away niyang mag-start via jump-start cables.
    happy buying.
    Feb 2018
    #177
    nothing dramatic.
    happy buying.
    Native toyota na ba yung 2017 wigo? di na rebadged like yung 2014?
    #178
    i think both 2014 and 2017 models are daihatsus at heart and in reality.
    but since toyota owns daihatsu, it is very easy to re-badge them as toyotas. badge-engineering is already global industry practice.
    because naman, who would buy these little beasties here, if they were badged as daihatsus?..
    personally, i got a wigo because i thought toyota would support me in the perceived build quality department, and in the aftersales.
    and also because, it cost only half as much as my intended target purchase at that time (an innova) when i walked in.
    Feb 2019
    #179
    nothing dramatic.
    happy buying.
    Yes im a toyota fan too. Just wondering about your jump start it should have started it if done correctly. I hope that it will be no headache buying a 2nd hand. As for maintenance I dont think it will be a problem since i will be using it as a spare vehicle probably it will run 2000 to 3000km in a year only.
    Jun 2005
    #180
    Not exactly in kaybiang itself but there are portions in the mountain that is quite steep that you really need to step on the gas.
    I used that road a few times before. Di naman matarik. I recall madami din ako nakasabay ng wigo and eon.
    Frankly, i think mas matarik pa ang kennon road going to baguio and sierra madre going to baler yet kinakaya naman ng wigo. So the road leading to kaybiang should not be much of a problem
    Sent from my MI MAX 2 using Tapatalk
2017 Toyota Wigo
