Results 4,691 to 4,700 of 5286
- 107
October 10th, 2018 02:08 PM #4691what's a cheaper alternative to the stock a/t tires (265/65R17) on my 2017 Fort G Dsl?
the stock is bridgestone dueler a/t 693, if im not mistaken.
just planning ahead when i may have to get them replaced eventually.
thanks!
- Apr 2009
- 429
October 11th, 2018 12:03 PM #4692
try other brands. You can check out other reputable brands ie; Yokohama, Goodyear, Cooper, Nitto. If you want a little cheaper check out other brands like the ones made by asian countries, Maxxis (Taiwan), Savero (Indonesia), Hankook (South Korea), etc
Window shop muna,,,,,
- Feb 2018
- 18
October 16th, 2018 09:06 PM #4693Hi tsikoteers,
Need your advise on this. My 10-month old fort has a shaky steering wheel at speeds ranging from 80 - 120 kph at may kabig din sya sa kanan. I recently got it balanced and aligned(including camber, negative camber daw sya upon checking). Drove home and immediately kumabig agad sya pakanan right after the alignment so I brought it back in the afternoon to have it aligned again.
The following day, I'm still having the same symptoms: kabig sa kanan and shaky steering wheel. I always maintained tire pressure at 29 psi as recommended in the manual and it's a fairly new ride at 14,000 kms. Hope you can shed some insights on this matter. Maraming salamat!
- Nov 2017
- 1,748
October 16th, 2018 09:20 PM #4694
BANNED BANNED BANNED
- Sep 2014
- 8,492
October 16th, 2018 10:09 PM #4695
- 54,195
October 16th, 2018 10:19 PM #4696
- Feb 2018
- 18
October 17th, 2018 09:20 AM #4697
- Feb 2018
- 18
October 17th, 2018 09:21 AM #4698
- Nov 2008
- 210
October 17th, 2018 09:50 AM #4699Bring it to casa, ipa warranty mo. I remember my dad adventure ganun din before nag 1 year, yun pala na oblong na, maybe naka under inflate tire nya running for many months without checking the tire pressure, good thing ni replace ni casa under warranty.
Sent from my SM-A720F using Tapatalk
October 17th, 2018 10:16 AM #4700
Follow the tire pressure settings indicated near the driver's door ... Also, after computer alignment, do not adjust anymore by doing a test drive ... If it still swerves, check the tires and suspension ...
Agree with you there. Nicely put.
2022 Mazda BT-50 (3rd Gen)
