Results 1 to 10 of 10
    Hi Guy's,
    Inputs naman dyan regarding sa 17" Wheels. As of now, 15" ung gamit ko. I'm planning to replace it with a 17" wheels.
    Do I need to upgrade also my excisting shocks?
    My car is a Vios 2008.
    Thanks
    Aug 2008
    Quote Originally Posted by cmadiam View Post
    Hi Guy's,
    Thanks
    no you dont have to replace the shocks. expect the ride to be a bit harsh though. the XX limited and S variants of the vios also have 17s stock rims. I have also a 2007 Vios and replaced the mags to 17s. just follow the tire profile of the vios S/XX limited. 205/45/R17.
    Hi Guy's,
    Thanks
    The ride will be very uncomfortable with 17s on a VIOS. You'll be better off with 16s as your biggest wheel size.
    BTW, handling deteriorates on the VIOS with 17s.
    Aug 2008
    don't know if the nitrogen affects the ride quality, the ride is tolerable w/ 17s filled up with nitrogen. not much of a difference from 15s, pero pag nalubak, dun mo lang mapapansin. kablag talaga. the factor that makes me want to switch back to stock 15s is the feeling of the vehicle being heavy with the 17s. noticeable specially in stop and go city traffic.
    Jan 2010
    Will 17s on a Vios make the odometer/speedometer inaccurate?
    enter mo lang specs ng stock and future tire/rim size.
    Tire size calculator
    Jul 2006
    tire size is a factor too. check it here: Tire size calculator
    Oct 2005
    mas OK pa pala mag 215/40R17 sa Vios kesa sa 205/45R17 based sa calculator. kasi mas maliit ang disparity.
    Salamat sa lahat ng nag input.
    Jan 2012
    Quote Originally Posted by basti08 View Post
    215's will probably scraped some plastics on your fender when turning.
17" Wheels
