Results 3,181 to 3,190 of 3192
- Nov 2019
- 1,404
April 19th, 2024 07:27 PM #3181
- Sep 2021
- 901
April 27th, 2024 04:53 PM #3182^^^
No, I've a separate clear book and plastic envelope with receipts, arranged in proper sequence. (OEM filters/Engine Oil/OEM parts)
I don't think I'll ever sell this though. On other, dedicated Jimny Forums, may mga 2nd gen. (SJ30 & SJ 40) pa rin sila that are still running up to this day.
- Feb 2014
- 2,694
April 27th, 2024 10:12 PM #3183
i used to have android auto disconnection issues until i tried this. usb 3.0 to type-c adapter, and C-to-C cable. i don't know why or how it works but it just makes the connection 100% reliable for some reason
April 28th, 2024 02:00 AM #3184
- Nov 2017
- 289
July 2nd, 2024 03:33 PM #3185
- Feb 2014
- 2,694
July 2nd, 2024 05:37 PM #3186
- Nov 2017
- 289
July 3rd, 2024 12:42 PM #3188
Got it ! I started using 29psi and will adjust slowly to my preferred setting.
I searched thru Australia and South Africa who are using a lot of 215/75 on stock rim and it ranges between 24-26 psi range. It could be depending on ply rating as well.
PH, a lot of folks used the 235/75 on stock rims which I find too big (maybe its just me).
- Feb 2014
- 2,694
July 3rd, 2024 03:00 PM #3189
yeah it depends on how stiff the tire is. on my 50kg ebike i use a 4-ply rated tire and it only needs 8psi on pavement
here's the chalk test on the rear tire at 18psi. it's actually still a bit overinflated. see arrows
take note there's another effect going on here. as you mentioned it's the wide tire, narrow rim. tire tends to bulge the center tread if on a narrow rim. 215 is already wider than recommended for the stock rim by just a bit
- Aug 2024
- 1
August 21st, 2024 07:41 PM #3190
How much room do you have between the battery terminals and the hood seeing the the 3SM is much...
