Results 41 to 50 of 93
June 15th, 2022 11:24 AM #41
More than 2 years ko nang pinag-iisipan itong TPMS na ito.
Mawawala na itong forum, di pa din ako decided.
Pero most likely lalagyan ko mga motor namin... then if all goes well, isusunod ko na yung cars.
June 15th, 2022 11:57 AM #42
Very useful etong tpms. Ma monitor mo in real time pressure ng gulong. Re battery life ng mga sensor ung sa FR sensor nung
sa akin mga 3 months lang inaabot then the rest mga 5 to 6 months naman
- Sep 2016
- 2,348
June 15th, 2022 01:29 PM #43
June 15th, 2022 02:53 PM #44
June 15th, 2022 07:35 PM #45
You're overthinking it. Just get it. They cost almost nothing now. Iba usapan 10 years ago when only branded ones like Orange were available (and those cost around 12k).
It doesn't just show you the pressure of each tire but you can also set it up to alert you if the pressure drops down to a certain level, usually giving you time to drive it to the nearest vulcanizing shop or safe area to replace it with your spare tire.
Before TPMS, you will only know it's flat when you literally feel the wheels bottoming out as the rims touch the tire tread.
- Sep 2016
- 2,348
June 15th, 2022 09:37 PM #46Nakatulong na sa akin once nung natusok yung gulong ko ng makapal na alambre sa Ortigas Extension. Unti-unti sumisingaw na yung hangin until nagwarning na yung TPMS na bumaba na sya sa sinet kong pressure. Ayun napatigil ako sa Shell sa may SM Pasig at nagpalit ng gulong ng de-oras.
June 16th, 2022 01:33 AM #47
yep. That's my modus too.
THere are times i even pull out the unit out of the truck if i know it will be in the garage for a lengthy amount of time. I just opt to usb charge the tpms from time-to-time on my home ofc desk.
It's a hassle to reset the units and the air tire parameters whenever the tpms monitor loses its juice & dies on me.
June 16th, 2022 05:54 AM #48
I've decided to pull the trigger and ordered the solar powered one with the USB charging option.
I got into the habit of checking each tire manually so I hope this would be a better alternative.
At the same time bought 2 sets (10 pcs.) of CR1632 batteries as they are said to last for only 3~6 months.
- Apr 2010
- 91
June 16th, 2022 08:00 AM #49Three months ago i bought a cheapo solar tpms on lazada and installed it to one of our service vehicles. After 3 weeks tumawag driver na may audible alarm. It's not the low pressure alarm but the high temp. Pinadala ko agad sa talyer and turns out nag stock ang front left brake caliper piston kaya mabilis numipis brake pad on that wheel. This tpms saved me a rotor.
Sent from my 2107113SG using Tsikot Forums mobile app
June 16th, 2022 08:39 AM #50
One can only hope.
